      Variable effort steering
      Has anyone tried, or succeded, in getting variable effort steering to work in a power system?
      It doesn't actually seem that hard, GM has an Electronically Variable Orifice to do just that that is used on trucks and such.
      It screws into the back of a Saginaw pump even.
      So all that is needed would be a controller...
      If this is new ground, cool but if someone has already done it cooler yet!
      KEith
      Nov 2004
      Norway
      Country Flag: Norway
      It also consists of a steering wheel rate/position sensor on the steeringcolumn, but I don't know about the controller. It MAY be incorporated into a ABS- or Body control module, either way retrofitting is probably a little hassle to do sucessfully.
      EDIT: And of course a vehicle speed sensor signal is needed...
      Thanks, Christian (@v8power.net)
      '77 Caprice
      '71 Chevelle Nomad - Perfect for roadtrips!
      Nov 2002
      Georgetown,TX
      Flaming River's new steering box is advertised as having variable effort.
      Yea the new vetts need the steering input, but it doesn't actually need to be connected to the steering...
      Flaming rivers pump isn't truely speed sensitive, It's Engine RPM sensitive. So if you have an overdrive tranny boost goes way up when the TC locks up.
      I'm pretty sure I can design my own controller that would just use the signal from the VSS or an addon VSS for those of us with a Mechanical Speedo.
      No steering input.
      Maybe a manual adjust tho.
      Apr 2004
      OKC, OK
      If I remember right my '90 IROC had variable rate steering. As system pressure increased with rpm, the steering stiffened up. When cruising in town, easy to make turns. It was very stable and always loved to drive that car.
      Mike
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      My 91 Taurus SHO had it too. It was a handful turning in as engine speed dropped, a little blip on the throttle, and downshifting all affected engine rpm, which affected steering effort. I disconnected it.
      Perhaps newer systems using VSS would be better, but even that with lots of trail braking could have the feel of non-linear response as vehicle speed came down dramatically going into a turn.
      jp
      ​John Parsons
      Good point!
      Looks like an on off switch is required!
