      Oct 2008
      Seattle, Wa
      Ridetech Triple Adjustable Coilovers
      I am selling a pair of ridetech Triple Adjustable coilovers for a friend. They were only used for 1 year and are in perfect shape. These are the 4.1" stroke versions but have 1" extended mounts on them. The coilovers do come with springs, and he has a few sets to choose from. These are valved the same as the 48 hour Camaro. I bought a pair just like this from him and am using them on the front of my 69 Camaro with StrongArms and the Chicane kit. Located in Ohio.
      $1000
      Coilover Part Number: 24349901 (http://www.ridetech.com/store/coilover-shock-4.1-stroke-triple-adjustable.html)
      Oct 2008
      Seattle, Wa
      Bump.
      Mar 2013
      Quote Originally Posted by Ryanater View Post
      Bump.
      I am interested in your shocks; do you know what the ride height would be? I have a Wayne Due frame with C4 suspension that I am hoping these will fit on a 67 Camaro.
      Oct 2008
      Seattle, Wa
      Sure. With the standard mounts, the compressed length is 10.125" and the extended length is 14.225". So the Ride height would be around 12". Since these have the 1" extended mounts, the ride height would be 13".
      If you need a 12" ride height, you can use the standard mounts on the shocks.
      Mar 2012
      San Antonio
      I'm interested in these, what length spring do they come with and what are the spring option? I would need 800lbs springs. Thanks for the info.
      Jacksonville, FL
      Are the extended mounts removable? (to put them into a stock subframe)
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Oct 2008
      Seattle, Wa
      Sorry these are sold.
      But yes they are. However, they would of been too long to use without the Chicane setup.
