      May 2012
      Royersford PA
      II MUCH Vent question
      I just purchased a II much vent and a ricks stelth tank. Question about the vent I know it has to be mounted vertically but dose it have to be strait up and down or can it be on a slight angel?
      Apr 2012
      Woodstock, IL
      It can be on a slight angle.. The main point is to keep it from holding fuel if it were to go into the vent. So if it's at an angle to where it cannot drain back, then that's not acceptable.
      How big of an angle are you thinking? I'd probably avoid anything beyond 30 degrees.
      -Dale
      SchwartzPerformance
      May 2012
      Royersford PA
      I ended up mounting it under the car where the trunk floor goes up above the tank we will see how it works there
      Dec 2007
      Wisconsin
      Quote Originally Posted by mike63078 View Post
      Is it a bulk head mount or a side mount??
      May 2012
      Royersford PA
      Side mount
