      Jul 2011
      t56 magnum leaking
      Ok so just got a new t56 magnum and 2 issues, one after taking a test drive there looks to be trans fluid leaking out of the rear seal and running down the the bottom of the trans onto the mount.
      Second when the cars sitting at ride height and I pull the driveshaft and yoke out it pours out a little puddle of fluid. I had a t56 before and never had this problem and the trans isn't over filled. I filled the trans at ride height until it dripped out of the fill hole. Also I used Amsoil synthetic atf. Also I have about 3/4-1" of yoke showing past the seal. Any suggestions?
