      Oct 2014
      1968 Firebird/2005 GTO LS2 accessory drive question
      Im getting ready to install an LS2 from an 05 GTO in my 68 Firebird. I am going with the C6 alternator bracket, C6 alternator and power steering pump. My question is, will I also need the C6 crank pulley? Or will the GTO pulley line up with the alternator, power steering pump,water pump and idler pulleys?
      Pensacola, FL
      You will need the C6 pulley. GTO will work with Fbody but nothing else.
      Oct 2014
      Got it, thanks
      Birmingham, AL
      Do you already have the gto drive brackets? Everything but the ac bracket should work and you can buy a quik or holley ac bracket for f body swaps and it is spaced the same as the gto stuff.
      Stephen
      Nov 2011
      Louisiana
      The alternator will hit also unless the sub is notched.
