    Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
    Results 81 to 100 of 112
    1. #81
      May 2015
      Nashville, TN
      Quote Originally Posted by nokones View Post
      Ms. Trackside:
      If you don't think that Corvettes should be allowed in CAM, what is your opinion/position on allowing the Chevrolet SS 4-Door Sedan in CAM. No debate, just curious.
      I (with a limited understanding of the suspension/wheel base) think that the SS should go with the CAM-C class. Not sure why it shouldn't be competitive with the 5th Gen Camaro. Is there something I should be aware of that differentiates the SS?
    2. #82
      Sep 2011
      Speedway In.
      Everyone who is directly involved with CAM at the SCCA National office level are on the same page. They know that a lot of rules will kill CAM and everyone has pledged to keep that from happening. In the current discussions all that is being looked at is how the 3 classes are split, weights, wheelbases, and cars to be added or deleted from the exclusions list. The only actual rule change should be outlawing Lexan windshields. And it was stated in the 2015 rules that would happen.
      Dave Dusterberg
      http://www.facebook.com/camchallengeeast
      1979 Aspen R/T (under construction soon to be #19 CAM/T)
      2002 Ram 1500 SLT
      2005 Magnum R/T
      2005 Mustang GT #19 CAM/C
    3. #83
      Lawrenceburg, TN
      Quote Originally Posted by IndyDave View Post
      What? no way and I just bought an entire Lexan factory in Botswana knowing that all CAM cars were going to have to run plastic windows!! awww damn
    4. #84
      May 2010
      Livermore CA
      I think the current cam rules are great. I ran last year at Crows Landing and we were all racing for second place behind Brian Hobaugh's Vett. I came in last, but it was a good learning experience. I broke my car at the T-Hill USCA so I couldn't run at this year's west coast event, but I'll be back next year and hopefully run a bunch of events.
      If I could make one change I would add CAM-U. An unlimited class with no minimum weight or wheelbase requirements. I am building a 28 Model A with a target weight of 1800# I don't want to add a 600# under body panel, but will if the rules require it.
    5. #85
      Jun 2013
      San Jose, Ca
      I have been lurking and just have a few questions and my own ideas.
      I believe CAM was designed to be a Hot Rod class, a TRUE Builders class something cool that would not fit into the normal classes. I am totally for this idea. Rodney's Camaro, LS powered would end up in Street Mod but yet he did the engine swap for driveability, instantly screwed (trust me I ran that class years ago). Cool car, great project that has more miles than my daily driver. These classes are made for that type of project.
      Ok, I have been asked in the past what my feelings are for the newer Corvettes. Here it is, being a true hot rodder/builders class going out and buying a C5-or newer, slapping some heads, cam, headers and suspension does not make you a true builder. If you take a C1, C2, C3 or (yes Ken I will let you have it) C4 and spend the time and effort to do a complete chassis swap, you are a builder (and have build a cool car in my opinion). As A Socal person has shown, we can't keep up with a STU car. As a few north-western guys have proven, we can't keep up with an A-Street car.
      OK, why can't we keep up with cars that weigh (let's just say) a lot more weight, and half the HP. It comes down to a few things.
      -Aerodynamics, yes at solo speeds it does make a little difference.
      -ABS, HUGE advantage
      -balance and a known working setup
      Aerodynamics do play a role and if an older car is against an older car, they are both stuck with pretty much the same brick. I personally would like to see more rules before it turns into AMOD. (which, trust me it will. We do have the HP to put the barn door on top of the car and a sucker fan under it)
      ABS- I have torn down and scrapped a winning CSP car to swap everything over to a chassis with ABS. Huge pain in the @ss but worth it. I do not believe ABS belongs in any of the older CAM classes. Meaning CAM-S and CAM-T. I do know the C4 Corvette do have ABS and it is an advantage but it is an older system. Personally I would like to see them disable it but for bringing in numbers I am fine with letting them have it (for now).
      Balance and Setup. just back to the new cars and working right off the dealership. Look at how quick the F-street Camaro and Mustangs can run with tires. Yes they have good drivers but how much testing would it take to get something garage built to get to that level.
      So, now my questions.
      in the current rules what limitations does the suspension or drivetrain have in any of the classes? So I could take my SS and install a c6 Corvette underneath it? Would be legal?
      I have heard people say old design. I say sure but no rules say you can't change it. In Bruce's Cobra he has designed and made brackets to bolt to factory locations (so no new holes or damage to the car) and redesigned the front end. Completely legal. I would bet if it was a kit car he would chop the front end off and start from scratch. For this reason I would rather not have kit cars legal but I do want to run against people, so bring it!
      I have also heard people say, I can't run with blank. Some of these competitors have years.. scratch that, decades. of auto crossing experience. Driving experience makes a huge difference. How many have gone to an actual autocross school? Had a local fast guy jump into our car and give you a ride? Even going for a ride in your own car can be an eye opening experience. I can tell you first hand setting up a nationally competitive car is difficult and not something you order over the phone. It takes time. The CSP car took me 5 years with changing things every run. The Bruce's Cobra has taken 1.5 years and we are not near the potential. If you think buying someone's setup or knowledge is going to make you win events you are wrong. I know Miatas best so I CAN use them as an example. On miata.net some people would say you need this or only run that. I would then comment. They would take the other persons advice because they posted more than I would. Well, they were wrong and lead that person down the slow path and I honestly don't know if they ever got fast. Do not take someone's advise without testing yourself! Testing takes time but you need to have a goal and even if one weekend is slow you need to keep focused on the main goal.
      Oh, I do think a new CAM for sports cars would be cool.
      See you at Nationals,
      Scott Fraser
    6. #86
      Sep 2014
      Sun City West, AZ
      Yes, the C4 Corvette's ABS system is an older system and the only advantage that this ABS has is keeping you from flat spotting the inside front tire on turns. The C4 Corvettes have horrible ABS systems and the stock brakes suck too. There is no way that you can drive this ABS system deep into a turn and brake late, especially if you don't have all 4 tires planted on the ground. The ABS is essentially useless in that case, it gets in the way of the braking effectiveness. If you spike the system and the ABS kicks in, you essentially do not have any brakes at all, the pedal just gets hard and it is difficult to push pass the ABS in these situations.
      Many years ago when I was running my 93 40th in Super Stock, I took the fuse out to see what would happen when the ABS was disabled, the inside tire would lock up every time when I applied the brakes but, the brake effectiveness was a tad better since the ABS didn't get in the way.
      Maybe if I pull the fuse and install a brake bias valve that may be the trick. I think I might try that when I get my car back from Lingenfelter.
      Kenny Mitchell
      [email protected]
    7. #87
      Mar 2013
      Livermore, Ca
      Reading through all this mess, it still hasn't been answered why c4 and up corvettes and vipers don't have a place to play here. They made a class for new model Mustang and Camaros, why not Corvette and Vipers. The turnout of c4+ Corvettes at the CAM Challenge west was proof enough of build it and they will come.
    8. #88
      Lawrenceburg, TN
      Quote Originally Posted by chetly View Post
      they already qualify for other classes....do you own a C4?
    9. #89
      Mar 2013
      Livermore, Ca
      I own a c5z. the c5 z06 has ZERO places to play competitively if you have more modifications than 1 sway bar and shocks (not coil overs, but shocks). They aren't allowed in Street Tourning, only base model Corvettes are. My car has a race seat because stock c5 corvette seats suck! It has both sway bars changed, 18x10.5 wheels on all 4 corners, JRi shocks, cold air intake, headers, high flow cats, x-pipe and its tuned. My car is an STU car except for the fact it is a z06. I Drive my car to and from events and like to run street tires. So, where do I go and play? Oh that's right, no where unless I want to run against cars on race tires in SSP. So locally AAS has made the allowance that we can run in CAM-S, and ya know what, there is no short of 5-6 drivers in the class every weekend instead of 2 (Bruce and Scott). So don't tell me by allowing c4 and up Corvettes and Vipers will kill the class. The only thing I see it doing is increasing it...
    10. #90
      Sep 2014
      Sun City West, AZ
      What SCCA class would a C4 legally fit in that was built to the extent of the Pro-Touring rules? Obviously, not stock. Definitely not Street Prepared or Street Modified with an after market engine block and/or suspension mounting point location modifications. There is no class for any Corvette in Prepared, SCCA took that class away several years ago. Can't legally run a true street production car in E Modified either. Hmmm, the only category that I can see where a street car that was prepared to the extent of the Pro-Touring rules is CAM and it looks like that CAM-S would be the appropriate class in accordance with the 3 existing classes.
      Unless, I am missing something, I am open to learning a little more about the SCCA rules and how my C4 Corvette would be legal in a non-CAM category.
      Kenny Mitchell
      [email protected]
    11. #91
      Mar 2013
      Livermore, Ca
      Also, look no further than the CAM challenge that happened at crows landing, how many late model Corvettes entered the event because they opened up the class to late model vettes. How many would there have been if they didn't, TWO (again, Scott and Bruce)!!!
      Then look at the SCCA Tour event held in Crows Landing. CAM-s had the 2nd biggest class (until they pulled their stunt) because of all the late model Corvettes. How many would there have been of it wasn't for all the Corvette drivers? TWO (you got it, Scott and Bruce)
    12. #92
      Sep 2011
      Speedway In.
      When CAM was created it was a single class. At that time there was some legitimate concern that it would wind up being a "late model Corvette" class so they were outlawed along with the Dodge Viper to allow the class to grow with the intended audience. The opinion was that late model Corvettes had other classes where they are or have recently been competitive. During the first year of CAM while the Corvettes were allowed, what we were seeing were SS and BS regulars coming over and dominating in the regions where they ran. Now that CAM is now a category we maintained the Corvette ban while things sorted themselves out. But with CAM/S being a real under performer in the CAM landscape, powers that be are seriously considering letting the Corvettes and Viper back in.
      Dave Dusterberg
      2002 Ram 1500 SLT
      2005 Magnum R/T
    13. #93
      Mar 2013
      Livermore, Ca
      I don't have a problem if they want to make a different class for the corvettes and vipers, but realistically who are the competitors that go to nationals in cam-s besides Scott and Bruce? Not allowing Corvettes and Viper will be the death of CAM-S, mark my words. I've talked with Raleigh at the CAM Challenge dinner and at the OUSCI finals in Vegas with the likes of Mike Maier and Brian and Steve Hobaugh and we've made our feelings felt.
    14. #94
      Lawrenceburg, TN
      per SCCA
      SS and BS regulars
    15. #95
      Sep 2011
      Speedway In.
      Well, right now CAM/S is almost non-existent, some go as far as calling it the Cobra only class. So we're re-visiting the cars we've said no to in the past. At this point it's all discussion. I haven't heard anymore since the last e-mail blast to the group. The C-5, 6 & 7's I'm not real comfortable with allowing in but I have never agreed with outlawing the C-4. While it was leaps and bounds better than the car it replaced, it certainly no where near the "super car" level performance that the later cars have. As for the Viper, autocrossing one seems to be an exercise in futility. Those things are road course focused machines and there aren't enough of them in autocross to worry about.
      Dave Dusterberg
      2002 Ram 1500 SLT
      2005 Magnum R/T
    16. #96
      Sep 2014
      Sun City West, AZ
      per SCCA
      Exactly, there is no legal class for any Pro-Touring prepared car, including all Corvettes, in the SCCA Solo categories except CAM.
      Kenny Mitchell
      [email protected]
    17. #97
      Sep 2014
      Sun City West, AZ
      If the C4s are allowed to compete in CAM in 2016, I hope that the C5s and newer Corvettes are also allowed to play. My position is the more the better so the class can learn and progress as a class. Also, you can have a lot more fun with a bigger class than a smaller class especially when swapping the lies. I like competing when there are a lot of cars in the class. It is very possible that Scott and Bruce will dominate the class for some time. That is Ok, we'll (as a class) figure it out so we can get that little Cobra and shut'em down (Oops, I think the Rip Cords' song had it the other way around).
      Also, let the Vipers play too. If it is american, let them play.
      As I mentioned in numerous letters to SCCA and the postings on this forum, do not exclude any car. Let the cars run and sort it out later, if necessary. If a bunch of Vipers and the C7 Corvettes come out and shut down the little Cobra and walk away from the rest of the new CAM-S class, than something should be done. Then, maybe a new class is justified, especially if the numbers are there to support a new class.
      Look at the numbers in CAM-C that attended the CAM East Challenge. The class was "HUGE" with old and new cars and I am sure it was fun to be there. I personally think the numbers are there for splitting the class between old and new CAM-C cars. If you continue to allow the new/modern cars dominate the class, you may see a bunch of the older cars go away. That would not be a good thing and I would hate to see that happen.
      Excluding cars is way outside of the club's philosophy/spirit in promoting the sport. Lets take a positive approach and make room for anyone who wants to play with Pro-Touring prep cars. If the numbers are there to warrant a fourth or fifth class, so be it, lets make it happen and just have some fun. That is how the Solo program, when it was called Solo II, grew many decades ago.
      If CAM grows really big just like the Solo II program did in the early days, maybe CAM will become its own entity. You never know, I think it would be a very good thing if that happens. I feel it will bring back a lot of people and their old cars that SCCA use to have before the Solo category rules and the classes got SCCA'd up over time. Besides the MGs, Austin Healeys, and a few Porsches, what majority of cars do you think that were autocrossing in those days. Yep, the cars you are seeing in CAM now. Yes, I know, the Corvairs where also running in those days.
      Come on SCCA, lets work together and make this happen, let everyone have some fun at this sport with their old cars again.
      There will always be one class winner and non-class winners in each class. No one is a loser because it was fun trying to be a winner and you win at the fact that you learned something from it. Now, you can put what you previously learned at the last event into action at the next event. That is what this sport is all about, learning, having fun, some more fun, and swapping the lies. If you're not good at swapping the lies, you will learn that art too. It usually comes natural if you play in this sport long enough.
      Indy Dave, I know the CAM Invitational is only two weeks away, I hope you will post or start the new discussion "2016 SCCA CAM Rules" as soon it is announced, or PM me with hopefully good news.
      Kenny Mitchell
      [email protected]
    18. #98
      Oct 2014
      Cañon City,CO
      wow good read.
      I am still new to all this,ran my first autocross ever at Good Guys Ft Worth in 2013,then again in 2014 I'm now running CAM-T with the local SCCA club SASCA here in San Antonio . I'm leading the class because except for 2 events this year I was a class of 1. My new rival is a 65/66 Mustang that changed tires from ESP and I'm 1.5-2 sec behind them (2 drivers same car).
      Just from the slow end of the field the only rule to split the classes would be a front tire rule 245 or less /255 greater of course my reason is personnel. to get a 255 under the front of an early Mustang is work ($).
      Now as for rules that may get approved. 2 door 4 passenger pre 72 ( or cars with pre 72 chassie/suspension) CAM-T no wheel base limit but must be +/- ? from stock. Yes Mavericks AMX's FAT (heavy) Pintos 3000lb min.
      You CAM-C and S guys can do what you want but leave me alone LOL. a manditory 4 door class....?
    19. #99
      Sep 2011
      Speedway In.
      Brian Mason penned the following in a discussion on the CAM Challenge East FB page similar to the discussion here. It is the absolute BEST description of what CAM is about.
      "I'm going to do my best Sam Strano and Lance Hamilton impersonation here so bear with me. I've driven in and been involved with SCCA Solo, or Autocross events for over 33 years, things tend to get stagnant and boring over time but also you become desensitized to things over time as well. A few years ago I attended the Holley LS Fest, well, it was more than attended, my local SCCA region was asked to help with the Autocross. Over the course of the next few days I was completely floored and in awe at what was going on there, there were 100+ drivers, driving their cars through the Autocross course and every single one of them had a HUGE smile on their face. Repeatedly drivers would come off course saying it was some of the most fun they've ever had in their cars. It didn't matter how fast or slow they went, they were smiling when they finished their run. I thought to myself, this is such a contrast to the majority of the SCCA solo events I've been to for years, it took a bunch of hot rodders for me to realize how grumpy most SCCA solo participants had become, to them it's a competition and there can only be one winner. Immediately after that event I begged for a pass to the optima Invitational event in Vegas following SEMA, went out there and saw the same thing, big smiles, laughter and camaraderie, except there people were spending thousands and thousands of dollars to drive their hot rod in a glorified autocross and loving every second of it!
      Fast forward a few years and now I'm fortunate enough to spend time at and around the three organizations involved here, the USCA, Good Guys and the SCCA. The three are very unique and have their own niche. It is very challenging if not impossible to build a car that will be competitive in all three under the current state of event segment operations but I also do not think that is the intended goal of the SCCA CAM class creators. IMHO the idea behind the class creation and rule set is to allow some place within the SCCA solo community for Good Guys or USCA competitors and enthusiast's to participate, gain seat time and enjoy their cars. The SCCA sanctions over 1,400 (yes, one thousand, four hundred autocrosses) solo events EACH year hosted by 115 different independently operated regions, that makes it easy and very inexpensive to find somewhere local to enjoy your hot rod. Sure the events are run by volunteers and each participant has to “work” and the runs are limited to often times 4, 5 or 6 total, but the system works, has worked for 40 or 50 years and is sustainable for the indefinite future. Each region is free to make their own supplemental classes and or use the National recognized classes as outlined in the rule book. This gives the freedom to locally cater to different demands, I know my local region (in the heart of Corvette Country and self proclaimed “Hot Rod City”) created a CAM-X class that replaced “S” that does allow C-4 and never Vettes and Vipers to run using the CAM ruleset, they also have a identical ruled “STO” class for the American V-8 powered swapped import cars, again giving these guys some place to play amongst other like minded participants. I think the CAM creators did an excellent job with the rules and classes, it is only the second year in existence and the biggest argument that can be made is what class a particular car fits into? Look at the times at the CAM east event, you could combine C and T and all the different cars would be as competitive in that one class as in any single SCCA national event class of that size. I think that's awesome! one neat thing about the CAM class is it was conceived, created and the rule set was written with out the involvement of the traditional SEB (SCCA Solo Events Board), it really doesn't even report to them and it is not a “national championship eligible” class, again, it's not created for competition so much as it is created to be experienced.
      One thing to note about experienced, veteran motorsports participants, whether it be SCCA soloist or road racers, they spend a lot of time understanding course elements and reading pavement irregularities and types, how certain elements flow into the next. Very good ones will measure gate width and slalom spacing, turn radius and braking/acceleration points, if you were to walk the course with any number of the top finishers at the CAM East event and asked them what speed their car will be travelling at any given point on the course they would be able to accurately tell you, doesn't matter if they've ever sat behind the wheel of the car they are driving or not. That is the difference between turning a fast run within your first three runs on course and taking 6, 8 or even 10 runs to get there. The CAM east event field was stacked with talent, by far the most talent a CAM event has seen to date. There were a number of talented drivers there most of which were in under developed/under tired cars, there were also a number of talented drivers who were not there for one reason or another. The field is only going to get better and bigger. I can think of many "east" drivers who are either building cars or had to scratch their CAM East entry for some reason and there are just as many "west" drivers who are out there as well. There is a reason these drivers are interested in this class, it's not because it's “easy pickings”, it's because it is really fun to drive and hang out with like minded enthusiasts.
      If you want to WIN maybe the CAM experience is the wrong class for you, pick an organization, a class, pull out the Rulebook and build a car to that rule set. If you want to hang out in the grid or paddock, have some fun and drive your hot rod creation as hard as you can and enjoy it for what it is then I think you've found another outlet to do so with the SCCA and the CAM class."
      Dave Dusterberg
      2002 Ram 1500 SLT
      2005 Magnum R/T
    20. #100
      Mar 2012
      Escondido CA
      That sums it up beautifully. I find it interesting in the San Diego SCCA that we (CAM-T and -S) are the only class that bring a BBQ and hang out together under the same shade all day, eating together, working on each other's cars, and a little smack talking about our cars and races. I think the "old SCCA" types didn't know what to make of us at first, but I think we have slowly showed them that CAM = FUN.
      1973 Corvette Factory Primer Car
      1969 Barracuda Convertible
      1967 Plymouth Valiant
