    Results 1 to 20 of 23
      San Jose, CA
      Mark VIII Fan and Custom Controller
      I have been really happy with the installation of my new Lincoln Mark VIII fan.
      http://www.racehome.com/images/april04/mark8fan.jpg
      The MARK VIII fan and 55GPM Meziere electric water pump work really well. Sitting in traffic in 98degree weather last week... The car ran at 175 to 200 all the time. It runs the same in the morning when it's 68 degrees outside. I am not worried it will overheat at all!
      I have it hooked up with a 75AMP Bosch relay. When the fan kicks on, the charging system gets a shock! The gauge runs up and down a lot.
      I found a new product I'm going to install. I found them by accident. I like getting info from a happy customer, he sent me to this place sells a controller that supposedly works really well on controlling the HUGE Mark VIII fan and its AMP draw:
      http://www.dccontrol.com
      It helps ramp the fan motor, rather than SHOCK the charging system. It also helps even out the temperature in the cooling system. Rather than having it HOT.... COLD.... HOT.... Which is not great for the engine. It's more gradual.
      Just sharing.
      Tony Huntimer
      RaceHome.com
      Sep 2003
      Tampa, Fl
      So the 60amp unit will be enough (that's the bigger of the two they offer)?
      Brian
      '68 Chevy Stepside-Fatman, HTH, 8.8, Baer, Hydratech, LS1/T56. I know it's a truck but you gotta start somewhere and I need the challenge.
      San Jose, CA
      Control
      Aparently the FK-35 works fine with the Mark VIII fan. Some people like to put one of the standard ISO relays on the Mark VIII fan. They are rated at 40/50 Amps. This sounds like a good thing... Right? Wrong. Unfortunately, when the fan does not have a controller to help it "ramp" up slowly, when the fan kicks on, there is upto a 100AMP spike! That is a good way to smoke your wiring harness.
      The DCControl.com controller removes the spike and controls the fan without all the extra wiring usually needed to wire the Mark VIII fan "the right way".
      Tony Huntimer
      RaceHome.com
      awesome!
      Hey Tony-thanks for sharing-I'm going to look into that controller for my fan. Initially I planned on running a 70-amp Hella realy with a 50-amp fuse and 8-gauge Monster Cable +12v supply wire to it. I don't think I would have a terrible spike problem, but I'd rather be excessive on the side of safety anyway. Thanks again! -Jabin
      Jul 2002
      Mesquite, TX
      Good find. I think my shopping list just grew a little.
      Jan 2004
      Iowa
      Fk-35
      I have been looking into one of these units why doesn't someone set up a discount or a group buy? I was thinking of contacting them but I can't seem to find the time.
      Kevin
      Newbury Park, CA
      I would be in for a group buy!
      :icon996:
      Mike
      Rockford Illinois
      Group buy ?
      I would be in for a group buy on this too !
      Jim Nilsen
      Ontario, Canada
      Group Buy
      Me too! Me too!
      I've been thinking about using one of these for my twin 12"ers.
      Ken
      My other car is a Vega.
      Anaheim, Ca.
      THANK YOU, TONY!! This is a great find, and one that the majority of us could put to good use. Thanks again for sharing. Also I would be in for a GP if one is started. George
      Mar 2003
      Petaluma, CA
      Cool!
      Tony this is a great find! I wonder if they are using a power FET to regulate the voltage/current to the Fan. If they are, there should be a big heat sink attached to it somethere. It is a good idea to regulate power to the fan. It will reduce the shock to the charging system as well as maintain a more even engine temp.
      Jabin- actually provding less resistance (large gauge wire) to the motor, increases the current spike. Less resistance = beter flow of electrons = bigger spike. The 50A fuse will help if the motor sustains long periods of high current draw, however short current bursts will not be caught by the fuse.
      Fuse ratings are typically 110%(of rated current) forever, 135% for 30min, 200% for 5 seconds and 350% for half a second. This means that if the current spike is less than half a second long (which it should be) a 50A fuse can carry 175A and not blow.
      The weak link in the system is going to be the relay. If the contacts are not all the way settled by the time the spike exceeds the rating of the relay, there will be excessive contact wear and possible sticking of the contacts. Luckily with this large of a motor the current rise time should be long enough for the relay contacts to have finished bouncing, so you should be ok.
      Anyway, I will not bore you guys anymore. A group buy would be something I would be interested in.
      -Jeremie <--deals with automotive electronic motor/lamp loads for a living
      Dccontrol GP
      Guys, I emailed the "contact us" tab and offered to set up a GP and I mentioned this site and told them how many people are showing a lot of interest. I sent the email out yesterday so I have yet to get a response. Keep in mind that if I can get on as a dealer for them I can get a better deal which means a lower price. That's what I'm shooting for. I'll let you guys know as soon as I get word either way if they are interested in a GP. Gonzo, your explanation of voltage spikes gave me a possible solution to a problem I've been having. Get with me in the electrical section, please??? -Jabin
      Newbury Park, CA
      Is there a way to use a treaded sending unit instead of the fin-mounted thermostat?
      Alta Loma,SoCal
      Just some info for you guys with the M8 fans. I had one in my 88GT mustang a few years ago. I ran a dual 30amp relay setup from an old Product Engineering fuel pump. I also installed a 130amp alternator. My guage never ever even flickered when the fan came one. Make sure the alternator is rated high enough, and use a large(4g) feed cable to help out.
      1965 Buick Skylark
      voltage vs. amperage
      I'm thinking I wouldn't have problems with just running a HD relay and a 50-amp fuse and an 8-gauge power wire BUT-you could have an alternator overcharging to 200-amps or have it undercharging at 25-amps and the voltage could still remain the same, so the gauge mostly likely won't give you an indication of how many amps your charging system is putting out-merely just the amount of voltage it's operating at. For example, I had someone who thought they had a bad battery because their car would not start and their gauge always read 12.5-13 volts. Well, using an ARBST type machine I found out that the alternator was cranking out a max of 225-amps under a full load @ 2000 RPM while the voltage reading was a consistent 14.10V from the regulator. I think the DCControl is something worth trying out-the way I see it is like this: sure, you might not ever see a high enough voltage spike to cause any damage BUT-if it did happen, what could the results be? It's not a chance I want to take I'll tell you that. Preventative safety is what I call it. -Jabin
      Aug 2001
      Mark 8 fan
      The Red Witch has had a Mark 8 fan on it since 1996 ? I think I have about 21000 miles on it now and the fan has been great. The Mark 8 fan is used in a production car. Does the production car use a device like is being discussed here ? It sounds like a neat piece but is it needed ? Just my thoughts.
      Mark Vlll fan...
      Charles, I think it would be a great upgrade-here is a quote I have from the service manual for a Mark Vlll-1997.
      "PCM determines when fan operation is required by monitoring coolant temperature, vehicle speed and air conditioning status. When operation is required, PCM signals VLCM to turn on fan to desired speed."
      This doesn't actually point to a voltage control, but maybe the computer controls it along with fan speed. Thoughts, anyone? -Jabin
      Well, I was contacted by Brian Baskin who owns DCControl, and he said he would discount $15 apiece for 20+ orders and knock off $10 apiece for an order of 10. I think this applies to everything in the catalog. -Jabin
      Rockford Illinois
      Fan and waterpump.....
      I agree that the controller for just the fan isn't really a neccessity but it will help increase the life of the motor.
      My main reason for choosing it is because I plan on running an electric water pump and with both items drawing as many amps as they do and the ability to help the life and efficiency of them together along with everything else in the cooling system it seems like a good way to go. I might be sorry down the road but someone has to go there to see if it's better.
      It's just a great thing that these fans are so inexpensive compared to the other aftermarket fans that claim to do so much and don't for the money.
      Jim Nilsen
      Right on, Jim
      You know, it seems as though a lot of aftermarket companies seem to hold (by their advertising) that people think if it doesn't exist in their catalogs, it either does not exist at all ot it is inferior. Maybe they don't realize the effort a lot of us will put in for something that may not be a direct fit for our cars but we can make it that way with a little creativity. I agree though-for the money, most every aftermarket electric fan can't come close to that of a Mark VIII. Interestingly, on my Mark fan motor it has the Siemens company stamped on it. They make aftermarket new/reman. blower motors, AC controls, etc. Seems to me Ford knows how to save money (ala GM) by out-sourcing certain things which in turn make it very affordable for us to purchase them new. Sometimes cost-cutting is a good thing. -Jabin
