    Thread: L99 vs LS3
      Nov 2010
      L99 vs LS3
      Is there a way to tell the difference between an LS3 and L99 other than seeing a manual or auto trans attached to it? Is there maybe a different number stamped on the block? Any help is greatly appreciated. Thanks!
      Oct 2013
      A l99 will have a water pump that is sort of spaced out as it has VVT and DoD which can been seen once you remove the intake the valley cover will have like a maze Pattern other than those two things the blocks and heads are the same
      Nov 2010
      What do you mean by spaced out?
      Jacksonville, FL
      Don't the L99s also have VVT? LS3s do not.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Jan 2013
      Cypress, California
      Quote Originally Posted by 130fe View Post
      That is correct. The easiest way to tell if you know what you are looking for is the camshaft timing chain cover.
      Nov 2010
      Is there a picture comparing the 2?
      Mountain Springs, Texas
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Nov 2010
      Thank you very much
