      Feb 2012
      Mocksville, NC
      Weird engine noise
      Have a freshly built 440 with a FAST XFI setup. It's not tuned yet but runs really rich. It's been broken in awhile back but recently during a startup session I hear a consistent "pfft" sound coming right from under the throttle body. The car sputters, dies, then a little bit of white smoke escapes through the throttle bodies. It almost sounds like one of Jay Leno's steam cars as he's driving down the road. Like I said, the car runs rich and is not tuned and everything is brand new. Thanks again.
      1968 Charger R/T, EFI,SC,6-speed
      May 2013
      qld Australia
      Country Flag: Australia
      vacuum leak maybe?
      Mopar or no Car
      Your either with us or Behind us
      Feb 2012
      Mocksville, NC
      Vacuum leak I can understand but would that cause a "poof" of white smoke to come out of the intake?
      May 2013
      qld Australia
      i dont know exactly what the white smoke is but when i was having running problems with my engine a while back and when the engine would die white steam/smoke would exit through the carb. i think it is just soemthing to do with the heat and unspent fuel in the intake.
      i would just try and diagnose if you have a vacuum leak first then once it is running okay that smoke should not happen anymore
      Mopar or no Car
      Mar 2011
      Ca
      best guess is a small backfire causeing the smoke, especially with a vac leak.
      Dec 2010
      Fredericksburg, VA.
      I would be getting it tuned ASAP.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
