    Results 1 to 17 of 17
      Aug 2013
      Holly, MI
      1969 Fastback Project- Pro Touring/Street/Race?
      Figured I'd share my "restomod" project. It was a brutally rusted 69, and not much came back from the blaster. I want the car to be able to handle and stop like a more modern car, but I wanted it to have more of a drag race flavor. Kind of like a mix of pro touring and pro street.
      The frame is 2x3 square tube steel, but it will have an integrated chrome moly roll cage that is almost entirely hidden, no door bars. Power will be from a 2012 "Boss 302" engine w/supercharger, running on e85. I've never had something like this, thought you guys might be interested, and might have some advice or learn something from this build.
      The wheels are 17" Weld RTS, 12" wide on the back and 5" wide on the front. The tires are M&H drag radials, the biggest 17" ones I could find in the rear.
      The frame will be cleaned up and angle cut on the front to dress it up a little. If you guys are interested I will keep the pics coming as the car progresses.
      Aug 2013
      Holly, MI
      The engine and trans are cores. The rear brakes and axles aren't installed yet, we're mocking up the tires to ensure that the rear end housing ends up the correct length.
      Feb 2013
      Berwick, South Louisiana.
      Nice build. Good choice on the full frame. If I was to do another I think that is the way I would go. Subscribed.Are you doing this build yourself?
      Aug 2013
      Holly, MI
      Quote Originally Posted by I_make_oil View Post
      Thanks. Unfortunately, this craftsmanship is way above my skill level. The car is being built by Eliminator Customs in Grand Blanc, MI.
      The rust on the car was worse than I'd originally thought. After stripping it down to the unibody and blasting it, we ended up having to change the tail panel, both quarter panels, the upper and lower cowls, and cutting out the entire floor. So basically I bought this old fastback for the roof and the rocker panels. Not sure why the rockers were still good, but they were very solid.
      Aug 2013
      Holly, MI
      Chris started mocking up the body fitment. Love this car so far. Lots of work left but it's going to be sharp and fun when it's finished.
      Nov 2007
      Dayton, Ohio
      Nice
      Not big on pro-street/drag but diggin the fab work.
      Roger
      69 Mustang coupe, under construction
      2011 Mustang - DD
      https://www.pro-touring.com/threads/...ang-SuperCoupe
      Freedom Of Speed!
      Aug 2013
      Holly, MI
      Quote Originally Posted by 69stang View Post
      Nice
      It was originally going to be pure pro touring car, but I am a hard core drag race guy, and have other cars that I drag race. When I started choosing parts for this thing, I just couldn't get used to the idea of the typical pro touring style wheels on it...and I think 17s are the perfect size. When I did a search to find the largest Drag Radials, the M&H popped up. It's not really "Pro Street", it still has 17s, the cage will be mostly invisible, and it doesn't have really giant rear tires and really small front ones. it will have a very streetable 800-850hp at minimum though. The transmission will be a 4r70w, which is a computer controlled overdrive trans.
      Sep 2011
      Southern Ontario
      What are you going to do for the transmission ECU? Are you going to have power steering?
      Aug 2013
      Holly, MI
      Quote Originally Posted by Peter Mc Mahon View Post
      The transmission will be controlled either by a baumanator controller (stand alone) or by the Holly Dominator system. I haven't decided yet. The Dominator can control transmissions, but doesn't have built in logic for the 4R70w, so not sure it will work for that. The Baumanator (sp?) will work for sure.
      Yes, the front suspension is from TCI, and comes with a power rack. The front cradle comes from TCI already set up for a coyote. Not 100% sure how the accessory drive will look when done.
      Sep 2011
      Southern Ontario
      My truck is not on the road yet, [but soon] so I can't comment on how it works, but I bought a Simple Shift for my 4R70W.
      The power steering pump/accessory drive/AC on these engines isn't the most 'off the shelf' thing going. I think Sean Hyland Motorsports has something for this.
      I am not supercharged, so I didn't get into those issues.
      Jul 2010
      Rancho Murieta
      Nice looking fastback, well what's left of it anyway! It's unfortunate you had to lose so much of the original bodywork but at least you saved it before it was completely gone. I REALLY like those rims, like you said, not the typical pro touring style but I think they look great. Can't wait to see more progress, i've always liked the fastbacks!
      93 RCSB GMC Sonoma Tubular Ub Machine UCA's, 3" Belltech coils, 3" Summit Racing leafs, ZQ8 front and rear sway bars,trans am steering box, KYB-Gr2 shocks, 255/40/17 Bridgestone Potenza RE760, Eagle 212 17X8".
      Oct 2014
      Looks great so far.
      1988 Mazda RX7 - Forged LS/T56, 76mm turbo, ProEFI, Ford 8.8 - Sold
      1965 Mustang Coupe - TT Coyote, TR6060, Haltech, big brakes, updated suspension.
      2007 Aston Martin V8 Vantage - Full bolt-ons
      2016 BMW 428iX GranSport - Stock...ish.
      Feb 2012
      compton IL
      this thing is going to be awesome ! i first seen it on VMF the other day.
      1965 mustang fastback. a pro-touring concoction of oem, race & custom fab...build thread here https://www.pro-touring.com/threads/...Racesteed-quot
      1975 harley ironhead custom long chopper. home built dream machine. fast, loud & beautiful
      Dec 2011
      That thing is badass, what a sexy looking body style. Ford in a Ford, amen
      Bossed
      Oct 2011
      Cincinnati Ohio
      We need to see more this is an awesome build
      Aug 2013
      Holly, MI
      Got a few new photos. The rear frame was extended and capped, and will be welded directly to the tail panel.
      The car was mocked up with the new body panels and put on the ground so that we could set up the ride height exactly the way we wanted it. I want the car in the weeds. I love it. I know it's not for everyone, but I think the stance will be perfect.
      Sep 2012
      London, Ontario
      Looks awesome! I like those wheels, they seem to be very popular lately.
      73 Maverick Grabber Project
      My never ending project:
      https://www.pro-touring.com/threads/...hlight=grabber
