    Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
    Results 61 to 80 of 103
    1. #61
      Jan 2007
      CT
      I think Moroso makes one that fits the battery tray. I think if you want the ability to ice down at a drag srtip at trunk mounted ice box would be a good solution it also comes with a sump style pump (looks marine derived). Or you can go interchiller (ac driven cooler). The Lingingelter pump is a what i am using its got a soft start and good for some serious flow improvement over stock.
      pump
      http://www.lingenfelter.com/forum_li...esting-results
      battery style
      https://www.summitracing.com/parts/m...UaAoVZEALw_wcB
      Trunk style
      https://www.ebay.com/itm/Rhodes-Race...QyM:rk:33:pf:0
      interchiller
      https://www.cspracing.com/forced-ind...ler-universal/
      ________________
      Nick S.
      Gold/Gray 1967 Camaro
    2. #62
      Sep 2014
      Wisconsin
      Hugely appreciate all the links. Thank you!
    3. #63
      Nov 2014
      I've been considering one of these tanks
      https://pnrwelding.net/ice-tanks%2Ff...sPage=products
      Using an interchiller sounds interesting but doesn't sound many people have gone that route.
    4. #64
      Quote Originally Posted by Nitrous View Post
      That's who built my custom tank for FNQUIK, I used it where the battery used to be up front. He does nice work beautiful welds. I agree about the inter chiller.
    5. #65
      Sep 2014
      Wisconsin
      thanks again! i do have the inner fenders in mine and it looks like the smallest 12x12x9 isn't going to fit that space.
      did you call and have a custom tank made? https://www.pro-touring.com/threads/...23#post1173123
      I see that specific post for the size/image but don't see it on the page for them. Thanks again for the link!
    6. #66
      Yes, I did we worked through e mail. I sent him a drawing of a tank I made a mock up in card board. I forgot a screen to contain the ice so it wouldn’t block the exit. It fit great.
    7. #67
      Sep 2014
      Wisconsin
      Huge thanks Wayne. Contacted and got mine on order. Changed it up a bit to have an internal pump in lieu of external but looking forward to getting it!
    8. #68
      You won't be disappointed.
    9. #69
      Nebraska
      Thanks from me as well Wayne! I ordered one as well. Do you happen to have any pics of how you mounted it? I told Paul to make it just like yours
      Lonnie
    10. #70
      Sep 2014
      Wisconsin
      Finally starting to get my stuff together. Unfortunately the bottom bracket when lined up with the 2 existing holes, positioned the C&R piece too far to the passenger side so none of the top mount holes lined up with the core support. I made some extra slots in the bottom slots to be able to slide it over, but looks like crap. Probably will just get some larger washers to cover those areas.
      For the top mounting area, the L bracket goes behind the front ledge of the core support, correct? So "inside" and the hood latch attaches like normal. This leaves needing larger bolts to go through both and use a nut on the backside. Am I understanding this correctly? The existing bolts there were in the car are definitely not long enough to be used
    11. #71
      Nov 2011
      Wylie, Texas
      I don't recall needing to relocate the holes on the bottom bracket, I guess I got lucky. The top bracket does go behind the front ledge of the core support. If I remember correctly you only need to move the nut clips that were originally on the core support to the holes on the intercooler and yes longer bolts does make the job a little easier.
    12. #72
      Sep 2014
      Wisconsin
      Thanks!
      thats my issue, the nut clips were not present on the original so they were bolt/nut hence the need for longer bolts. But i wasn't thinking I could just replace the nut clips! So thanks!
    13. #73
      Quote Originally Posted by blitzer454 View Post
      The bottom holes lined up on mine too.
    14. #74
      Feb 2011
      dallas, tx
      So I’m about to take this dive. Is this heat exchanger really worth $750 instead of getting a factory zl1 for a 3rd of the price?
    15. #75
      The C&R piece is bolt in, or close to it. If you don’t mind a little fab the ZL1 should be fine. The hood latch is a bit of an issue with the C&R. I used the Screamin Performance remote hood latch.
    16. #76
      Feb 2011
      dallas, tx
      So I just installed mine tonight. Word to the wise take the card board out before mounting everything lol. Sucks that I had to take the condenser back off. As far as the hood latch there is no way a 67rs latch will work. Currently looking at options now
    17. #77
      Feb 2011
      dallas, tx
      For anyone installing one of these I found some hoses that work perfect. Gates 28481 are 3/4” x 60” with a 90 degree bend. I just ran the 90 off of the heat exchanger, drilled two holes in the core support, and used vintage air heater hose grommets 33137-VUI to protect the hose. You will need 3 of these grommets bc where you still the hole for the lower hose you will need to put one on each side. Just waiting for my varimax pump to figure out where I need to drill another hole in the core support. Plan is to have it laying above the core support bolt.
      https://www.facebook.com/photo.php?f...type=3&sfns=mo
    18. #78
      Jul 2011
      Great tips guys,I will be installing mine in the next month
    19. #79
      Nov 2009
      Austin Texas
      If anyone needs a pump or reservoir I have a factory CTS-V pump and a resi off a magnacharger kit. $100 for both.
    20. #80
      Jul 2018
      Fellas, feel completely useless, don’t post on here much(at all), I’m at the end of a long night working on my VA install, total pain in the ass when you don’t take the fender off haha..
      Anyway, the bottom bracket is stumping me on this C&R exchanger.. I’ve searched for an explanation on the internet to no avail. How does it attach to the rad support? Only one of three holes goes through, the other two only have the hole on the front? Am I supposed to drill the other two out for access to the back? What’s the spacer for? These washers don’t even seem big enough to catch the support haha..
      Any insight on this is appreciated, kinda stumped. Didn’t want to start a new thread so bumped this one.
