      California
      UGH, I need some engineering guidance
      Well, I have not gotten far enough into my engineering school to remember how to do these calculations without some help. I need some help figuring out a load capacity for a beam.
      The beam is a W12x22 I beam 18' long. I am trying to determine if the beam can safely hold a 2750lb load at 17' from the supported end. The beam is cantilevered, and is pinned on one end and unsupported on the other. There is no triangulation, or support other than the joint opposite the loaded end. It is an evenly distributed load with minimal torsional forces acting on the beam.
      I have looked at some of the information I can pull of the web, but some of it contradicts other information. I appreciate whatever help anyone can give me, I would ask my engineering instructor but he is gone until Monday.
      Thanks again!
      Apr 2013
      Can you upload an image of the problem, or possibly an FBD of the beam. The pinned cantilever seams odd to me, as I've never had a beam problem with a pinned cantilever. The pinned end will still allow rotation of the beam, therefore the load will just rotate the beam around the pinned end. Is there possibly any other supports, or could that end possibly be fixed
      Dec 2009
      San Diego, CA
      I'm assuming not pinned as TCRugger stated if pinned it will continue to rotate. Stress = Mc/I. M= Bending moment (2750 x 17', remember to convert ft to in or your units will not work for stress which is psi); c= 1/2 the height of the I-beam; I= moment of inertia for the W12x22 beam. Remember "I" will change depending what side of the beam the force is applied. Do you have a safety factor you need to meet? This website may help for the formulas for different scenarios.
      http://www.engineersedge.com/beam_calc_menu.shtml
      May 2010
      kitchener,Ontario,Canada
      There are so many other factors here before the beam....i would say most definitely the beam can handle it...it's HOW the cantilevered end is secured to the floor, hardware,the MPA of the concrete etc etc etc
      Ryan Austin
      On Instagram ryanaustinss70
      California
      This is the best representation I can find. The main mast (grey tube) that the L-fame (yellow beam) will be secured to is an 8"x8"x 3/8 box tube 16' tall. The base plate is 24"x24"x3/4" with (12) 3/4" precast J-anchors, sunk 24" in a machine base (foundation) that is 4' x 4' x 3' with 5000 psi concrete reinforced by a good amount of 1/2" and 5/8" rebar. The pivots are 1-1/4" grade 5 bolts 8" long with a bearing set that is (tapered roller bearing/needle bearing/needle bearing/ tapered roller bearing), there are two pivots set up like this (top,bottom). The Y-axis spacing of the pivots are 6' center-to-center. In addition to the machine base, the main mast will be supported by 3"x3"x.120x20' tube(s) at 45 deg to the Y axis and perpendicular to each other. The "outriggers" will bolt to the existing floor (6" reinforced slab) with a 12"x12"x1/2" plate. The plate will be mounted with (4) 3/4" epoxy anchors.
      May 2010
      Very similar to some of our jib cranes at my work pretty sure it will handle it, let me refer to ours on Monday and I will get back to you
      Ryan Austin
