- Sep 2008
- 24
tko-600 quicktime bell starter issue
I just finished up the conversion of my 5.7 hemi from a 4l60e to a tko-600. I used a Quicktime bell and flywheel from American Powertrain. I've got a bit of a problem though.
When I start the car, it starts just fine but when I let off the key the starter chirps almost like its grinding on something. This does not happen while the starter engages or while the car is starting...just at the very end when the car actually kicks over. I used the same OEM Chrysler starter that was on the motor before I did the conversion and this chirp was not there then.
Coming from a GM background I figured the starter needed to be shimmed out slightly. I searched the internet and could not find anything resembling a 5.7 hemi starter shim so I'm concerned that this is not the right approach. I used the Quicktime supplied reducer bushing for the upper starter bolt.
Any ideas what I should do? Is there supposed to be a gasket/bushing between the starter and bellhousing?
The guy at Quicktime didn't have any ideas. The guys at American Powertrain said to shim the starter with washers.
