    Page 3 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
    Results 41 to 60 of 150
      Jun 2014
      East coast.
      Calipers.
      FYI
      Piston count means nothing. how many pistons you have means 0.00000 to performance. Going form a 1 piston to a 6 piston will not increase your performance AT ALL!! there is a knee in the graph, but generally speaking the more pistons you have the worse a caliper gets. a caliper needs not to be judged by piston count but instead by rigidity, and piston size.
      Pistons,
      Everyone remembers the digital Camera war of Megapixels. Nobody knew what the flip a megapixel even was. The marking men said this camera has 4 pixels and that's better then 3 pixel. when in fact the amount of pixels it had meant nothing to the quality of photographs. it was a trick to get people to buy the next model. Brake manufactures have done the same with piston counts. They say "OH look a 8 piston!! buy now!!". The fact of the matter is this - the more pistons you have the worse your fluid will travel to all the pistons consistently. We found that the ideal number of pistons to have in a fixed caliper is 4. 4 pistons push evenly on all edges of a pad, and it can still keep consistent fluid pressure. we have also found that more pistons you have above 4 the less consistent a caliper becomes with fluid delivery to each piston. The only time we've seen 6 pistons be better performers then 4 pistons was is the size of a caliper was an issue. in NASCAR, we use 6 piston caliper to clear that tiny 15" wheels. for 90% of the applications out there we don't need to worry about that. so that 8 piston caliper you've been eyeing... run away from it.
      Rigidity
      a caliper is only as good as how stiff it is. a solid caliper can be felt in the peddle. time after time the peddle can be relied on to be in the exact same spot. If your reading this and not agreeing then your system is in desperate need of improvement. flex of the caliper is the same as the flex in the lines. people go crazy with stainless brake lines. they do this because it improves peddle feel. Unknowingly, they swap the stainless lines onto a caliper that flexes. the stiffer a caliper is the less it will flex. A flexing caliper requires the pistons to travel further to apply the same amount of pressure. the extra travel in the pistons means the pistons are moving further out of the bore. they will need to travel further back into the caliper to be able to remove pad pressure off the rotor surface. A caliper, let me restate that. a Good caliper has square O rings. these square O rings retract the pistons only so much. for example lets say 1mm. if a caliper flexes and the pistons need to travel 1.1mm that means the O rings cannot retract the piston, and you will still have residual brake pressure on the rotor. that residual pressure is creates drag. The Drag is acting like the brakes are still on. imagine you heading down the back straight. how much more MPH do you think we can get if your brakes where off.
      Piston Size.
      we have gone over this before, so i wont go too in depth about master cylinder ratios. i will focus on the pistons themselves. Everyone overlooks the piston size. so your calipers are a 12 piston.. your pistons must be the size of dimes. that's not a good situation. When looking at a fixed caliper we want to see 4 large pistons. this gives us the best hydraulic advantage.
      Jun 2014
      East coast.
      Quote Originally Posted by Nicks67GTO View Post
      Here's a real general one that I can't seem to get my mind around....
      Why does a front set of Brembo brakes for a newer ZO6 Vette command $4-8K?
      http://www.carid.com/2006-chevy-corv...2FgaAn3T8P8HAQ
      Is it a materials and machining thing? It just seems absolutely ridiculous considering a stock ZO6 brake setup is pretty darn good in its own right. Is it just a status thing or are they actually that much better?
      allow me to answer this in order... Yes, Yes and Yep.
      First off are you asking about comparison to the C6z brakes, or to the c5z? when you see a brake kit start for 8k you can begin to think "this might be a quality system". after that start to do some fact checking. where does the iron come from. you can machine the rotor in the usa, slap a "made in the usa" sticker on there, but that doesn't mean the iron is from america. allot of places will lie about where the Iron will come from so watch out for that. when compared to a oem piece the aftermarkets are much better. the OEM piece is engineered to look like a racing caliper but be cheap to make. stop tech has a good side by side video. the video demonstrates caliper flex in a OEM fixed caliper. Yep your going to pay for the "brembo" name. Brembo knows they got a good name, and your going to pay for it. let me explain it this way. PFC makes a corvette kit. it's exactly the same as the brembo one (except the rotors are slotted, not drilled) and that kit costs $7,500 for front and rear.
      As a Professional brake guy a 8k brake kit a good starting point. Our GT "race" brake packages they start at $10k, most of our NASCAR Short track packages Go for $25K, and our Carbon Carbon kits start at $250K. If you walk in with your street car, am i going to try and sell you a nascar Braking system? ..i'll anser my own question by saying "Hell no". These kits wont stand up to road salt, or general day to day abuse they will slow you form 200mph rapidly. Moving a 25k nascar package would be a good sale for a sales man, but not the right fit for one of my customers. it's all about matching up the brake system to what you need. I'll make sure the calipers, rotors will be what you want.
      Calipers.
      Lets go and tell a story about this shady tree corvette shop that i now refuse to do business with. They had a customer with a c5z corvette used for track days only, no street time. it was taken to the track and put away until the next track day. Before i came around they had sold this guy a $15K brembo Racing system. I think they pulled the wool over this guys eyes to get the sale, because he was pissed about it. They must have done the old "he wants a BBK, put the most expensive one we can find on there. We'll tell him about the price when he see's the bill". I kept hearing the owner of the shop tell the customer "i'm sorry about the brake system... i didn't know it was that much...ect" . Little to everyone's surprise that was the exact kit that car needed. it was a nickel finish, 360mm, monoblock 4 piston Brembo Racing Brake kit. it's perfect for track day only car (aka a race car). that kit was 15k but it will never give him a headache, drag, nothing. the owner of the shop and the customer had no idea what they where doing, and completely got it right. if they pit that kit on a road car or a double duty (street/race) the nickle finish would deteriorate and the whole kit would fall apart. so they accidentally did the right thing. they did the right thing with the right parts not right thing buy trying to screw the guy. if we have a road car it needs to have a coating that will protect it from the elements. it needs to be set up for the long haul. thankfully those calipers are less expensive then the Race versions.
      Rotors
      That brembo kit you listed i wouldn't recommend that for any car. it has drilled rotors. Drilled.. shoot me. i've been talking to people about how awful drilled rotors are. All i get in response is "are you sure?". Yes, I'm flipping sure that drilled rotors are crap. Fact of the matter is it cost 3x less to drill a hole then it does to cut a slot (that's why the oem's do it) . Someone decided that "I'll cut my rotors to look like racing rotors.. but all i have is a drill press" and then the drilled rotor was born, just to make my life harder. Sorry i'm normally a more positive person... The holes are said to release gasses. i have no clue what gasses they are talking about, if your pads are putting off gasses you got the wrong pads, and an marketing major came up with that quote. the holes themselves actually remove a lot of material from the rotor. This material is desperately needed for the rotor to cool itself. think of it this way it's easier to start a log on fire if you put the flame on the thinnest part of a log. because the rotor has less thermal capacity and is easier to heat up it will be easier to fail. yes i'm sure...
      Sep 2011
      Southern Ontario
      This is good stuff, thanks for the input so far!
      Aug 2005
      SF, Bay Area
      Great thread! Tagging for reference later
      1965 Chevelle. PM me about wheel tool rental
      May 2009
      Houston
      Hi, I was going to create my own thread, but on the first page there was one similar and then I seen your thread OG Racing and wanted to ask you a question about the brakes that I am going to be putting on ... mostly what to expect and what I probably am missing.
      Vehicle: 1987 Silverado 1/2 short bed, sticker on door says 5600#
      Stock combo valve
      Stock Master cylinder - 1.125" bore
      Current brake setup is stock front caliper and c5 or c6 caliper.. forgot which one I bought 7 years ago from Tobin at kore3
      Front Stock caliper @ 2.9" pision
      Rear C5 caliper @ 1.77 piston
      online Brake bias calculator showed this to be at 70%
      Stock combo valve
      Stock Master cylinder - rockauto says 1.125" bore
      Never had any brake issues, but since Im doing a Gen5 LT swap and wanted more woa power figure upgrade the brakes.
      Engine: Stock Gen5 355HP/382TQ
      Tires 265/55/17 (pretty sure)
      Recently seen Wilwoods c-10 pro spindle and picked up a set for a good deal) to incorporate the c6 front brakes (no research, just impulse buy) ... hours of research and ploting info into autocad - found out its not possible to mount that caliper to their spindle... after some autocading 07+ Silverado calipers might work. Few templates later, got the 07+ Silverado 1500 calipers to bolt up on a 12.9" x 30mm rotor. (stock rotor is 13"x30mm)
      So the new brake specs
      Front: 2 piston 2.0" on 12.9" rotor
      Rear: 1 Piston 1.77 on 12" rotor
      stock brake pads
      online Brake bias calculator shows it to be at 73%
      07+ trucks show to be a 1.25" bore master cylinder, which the 3/4 ton c10 tuck / suburban is offered, but in ugly cast iron assembly :( from research larger master decreases pedal travel and lowers brake psi.... the trade off.. Also offered is a 1" bore master cylinder - increase pedal travel and psi..
      As far as what to expect - do you think it might be necessary to remove stock combo valve and install and adjustable combo valve? change master cylinder. once installed, I will have a feel what the brakes are actually doing, but I am just trying to plan ahead for what to look for and what I might expect.
      Clint
      Jun 2014
      East coast.
      1. Just got a 1969 Mercury Cougar, discs in the front, drums in the back. I'm going to get new rims, so size constraints aren't going to be a problem for the rotor size. I'm going to do a pro-touring set up, and plan to do track days and road courses. Stock weight, and I'm trying to do it on a pretty strict budget. If I don't have to do a complete redo of the master cylinder and everything, that'd be great, but I'm looking for some serious braking power.
      2. 4 piston brakes or 6 up front? Disadvantages and advantages of both
      3. Recommended rotor size
      4. Power assist brakes. Good or bad? How expensive would it be to do to my cougar?
      F23
      1. Serious Braking power starts with a Serious Tire. we could put the largest brakes in the world with a GT-r Sized 409mm rotor, if you have a 255mm all season tire then you wont be able to use it.
      2. 4 piston. all day every day. The more pistons a fixed caliper has the harder it is to get an even amount of pressure to each piston. The only time we do a 6 piston is for NASCAR. fitting a 323mm rotor and a caliper under a 15" wheel is a real choir. At that point we need to go to a 6 piston to keep the caliper OD smaller.
      3. for a 3000lbs car with 300hp we could get away with a 12-13" Floating rotor with hats. It will be able to fit under a 17x9 wheel with a 275 tire.
      4. for a street car. keep them. Race cars I like to go full manual. you'll get allot better feel with a manual but it will take extra effort to make the car stop on street pads.
      Dec 2008
      Detroit
      This is great thread and its good to have someone with such vast knowledge helping us that need need it. I only have one suggestion :maybe people asking questions in individual threads and placing OG racing in the title if they want you to answer. I could see lots of good questions and your replies getting buried 8 pages deep in this thread by New Year....
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Jun 2006
      Katy,TX
      Got one for you on my 97 Chevy 1/2 ton I use to tow the hot rods. Front calipers have a 2.94 piston and a 4.95x2.99 inner/5.50x 2.35 outer pad size. The 3/4 ton calipers bolt on and have a 3.15 piston and a 4.95x3.37 inner/5.80x2.32 outer pad size. Worthwhile swap or will it affect pedal feel much being a 7% larger piston? Good pad for a street tow truck? Hawk has a truck pad.
      1965 GTO project car
      2004 Pulse Red GTO
      Jun 2014
      East coast.
      Quote Originally Posted by Skip Fix View Post
      your going to have a 7% larger front piston area. is that good for increasing brake tq? yes it is. 7% is also a good area to incrementally increase pressure by. But how is the braking balance? by increasing the balance of the system forward your removing braking duty from the rear. if your system already has a heavy Front balance (if you have rear drums a heavy front bias could be the case) then a larger piston will be shifting even more bias to the front, making the braking overall performance even worse. this could result in higher braking temperatures on the front rotors, if the rotor temperatures get too high you would loose all braking performance. When towing you have allot of weight and increased traction over the rear wheels. if your looking to increase the stopping performance i would look to adding more tQ to the rear of the truck. take advantage of all that extra weight you have.
      For increase braking demand i would look to the PFC .10 compound. it's made from an old nascar race compound but modified to not squeak or dust too much. it can take a rotor temperature in excess of 1600* (most street pads fall off around 800*). we have the PFC 0369.10 for 1997 chevy 1500's for 57.64. i would also look to see if there is a rear disc conversion for your application. FYI going drum -> rotor does require an aftermarket proportioning valve.
      Jun 2006
      Katy,TX
      Thanks, looks like staying with the stock calipers is the way to go. The 97s have ABS and barely use the rear brakes the way the stock setup is. I think I have over 100K miles on the shoes and still plenty left! Engage the ABS and the pedal feel real good. Been weird since new.
      The PFcs have a real good cold bite also? Most moron drivers pull in your stopping distance then hit the brakes themselves expecting you and 5000lbs of trailer and car to stop n a dime!
      2004 Pulse Red GTO
      Jun 2014
      East coast.
      the cold bite is there, but the hotter they get the better they work.
      Jun 2006
      Katy,TX
      rear shoes that match the pads for coeff?
      2004 Pulse Red GTO
      Jun 2014
      East coast.
      i don't do shoes, sorry. I would strongly recommend upgrading to a Rotor/ Floating caliper for track days. The brake drum is not a very good braking design, they are heavy, don't cool well, and can reach unbelievably high temperatures at a track day. a rear disc conversion kit is strongly recommended.
      Feb 2007
      Tinley Park, IL
      Proper way to set an adjustable proportioning valve?
      I was told "slam on the brake and adjust it so the back doesn't lock up" but that just didn't seem right.
      Nick ~
      1969 Cutlass
      Jun 2014
      East coast.
      Quote Originally Posted by Mr Nick View Post
      like it was said before braking is dynamic. that means Different actions will bring up different reactions. Example if your driving down a straight road and slam on the brakes your Fronts will lock up first. with the exact same setting If your entering a turn you might slam on the brakes and the rear tires will lock up first. all factors of your chassis set up will change these retractions. the factors in your chassis set up like weight distribution, speed, tires size, tire compound , brake pad, shock settings, spring rate, driver input, brake pad tq, ect. The rear brakes locking up will cause the rear to "step-out", "over-steer" or "trail brake". This is because in a turn, your inside wheels are unloading. The weight is shifted from a neutral state to forward, and left or right. this shift in weight will shift the traction forward and off the rear tires. An overseer condition caused by the brakes is called "trail braking". Trail braking is used by Racers to turn the car into a corner. To a novice racer trail braking can be surprising. Without knowing how to control trail-braking It can result in a spin, spins can result in crashes. for my beginner drivers i try to avoid all trail-braking. i want them to have the car slowed before the turn. once they have mastered slowing the car before the turn, then we can learn how to use trail braking. For a street application i would crank the brake bias knob +2-3 turns from off. this means that the rear brakes are mostly off. most of the time with this setting your front wheels only will lock up. that Lock up also called under steer". under-steer is disable in a panic stop situation. on the street it's easier to recover from under-steer then it is to recover from Over-steer. it will keep the car pointed in a straight line in a panic stop. To tune the prop valve take the car to an autocross. start with the valve shut. every autocross run open the bias knob a half turn, until you feel the rear of the car want to step out under braking, then back the knob off 1/2 turn. Then your at a Happy medium with brake bias pressures. record how many turns the valve is from off, and that will be a good autocross starting point. When driving on the streets crank that knob back 2 turns to remove pressure from the rear. This will insure that if your in a panic stop situation you won't spin out into the weeds.
      SoCal
      It's a good starting point. Assuming the surface isn't overly dusty or slick, that will let you make a good guess at the brake bias for straight line braking.
      A bit more thorough explanation might be find the point where all four wheels lock up at once and then remove rear pressure/bias.
      Most likely, you have a pressure limiting switch on the rear lines (this kind of knee point adjusting device should never ever be on the front brake lines). Start with as little rear pressure as possible and gradually add more rear brake line pressure/braking torque. Once at the point of 4 wheel lock up, back the rear pressure off at least two turns.
      There is a pitfall to this sort of testing, especially if done in a parking lot. Often times, the convenient long stretches of asphalt with low traffic don't have the best traction. This limits the coefficient of friction which limits the rate at which the car can slow down. For ideal bias, the car will need more braking torque in the front for higher rates of deceleration with more weight transfer. It would then be possible to think you had the bias correct only to find the rears locking prematurely at a driving event with a more ideal (clean) racing surface.
      Autocrossing can help reveal whether or not the bias is appropriate for dynamic situations, but this does not replace straight line testing. The typical autocross course doesn't have a significant enough braking zone to test threshold straight line braking at high rates of deceleration. Conversely, getting the bias safe in a straight line does not necessarily guarantee that the car will turn in without the rear losing traction first. Both are important tests. If in doubt, run less pressure in the rear.
      Brett H.
      1979 Pontiac Firebird Trans Am
      1991 Mazda Miata
      2005 Ford Mustang GT
      1987 Ford Mustang GT - Sold 06-29-2014
      1988 Oldsmobile Cutlass Ciera - RIP 9-17-2011
      1992 Chevrolet Corvette - Sold 10-12-2017
      Jun 2006
      Katy,TX
      Nick not a "expert" but that is kind of how you get the initial setting. I usually find a gravel driveway/road first as you can hear see it without as hard a "slam". But remember at the track street things are my dynamic -what was fine in a straight is totally different in a turn, harder braking can unolad the rear more(esp if soft front springs/large sway bar setup) do rear can lock up easier. Rear suspension too tight(springs/sway bars) in a turn inner rear can lock up. So you have to find the right spot to balance all of those, or tune to specific tracks, driving.
      2004 Pulse Red GTO
      Jun 2006
      Katy,TX
      Drums for the tow truck.
      2004 Pulse Red GTO
      Jun 2014
      East coast.
      Oh got ya, thought you where talking about your TA. sorry i don't have any shoes for drums.
      saw this today. ugghhhh love!! Big old PFC brake kit.
      Feb 2007
      Tinley Park, IL
      Thanks to you guys for the input on setting my prop valve. It's cold here in Chicago, so this will have to wait till Spring. The GY Supercar tires have poor traction under 50*, so no point in setting it now.
      Nick ~
      1969 Cutlass
