    Results 1 to 11 of 11
      Aug 2014
      Country Flag: Italy
      Carburated LS3 VS EFI LS3
      What do you think about ?
      Jan 2014
      Sacramento, California
      Jan 2014
      no real answer just whatever you want to do but thats the link to recent forum
      Jacksonville, FL
      Post 3 on that link says it all. Nothing wrong with what ever way you go, just depends on what your needs are. I have had EFI in my car since 2000 and don't miss the carb at all.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Jan 2014
      if you dont mind tweaking your carb for temp and altitude go with the carb. efi just tweaks if for you. pretty much all there is too it
      Jun 2010
      Deployed
      If you had the option to go FI, why not? There is nothing nicer than having your car start-up and run like a modern car.
      I don't recall the last time I flooded my car, died under hard breaking, or complained about the crisp throttle response. ;)
      Don't go carb unless you have a legitimate reason.
      A well tuned carb can be very drive-able and reliable. I have found since going back to a carb, I don't like the pedal feel of getting into the secondaries. The power is difficult to modulate once you get into them, kinda like an on-off switch.
      Sep 2014
      No matter how well tuned a carb is, you won't be able to reach through the window and start it! (even cold!!!!)
      Dec 2013
      York, PA
      I just got my LS3 project done, EFI. The only way I'm ever going to use a carb again is if the car is original and came with it. No way I would use a carb on one of these.
      Just my 2 cents.
      1969 Camaro SS 350 LeMans Blue
      2015 Camaro Z/28
      1979 Li'l Red Express
      Aug 2014
      Country Flag: Italy
      Thank You for the help guys !
      Another question:
      For swapping my LT1 to a LS3 what I have to change ?
      I think motor mounts and headers, about the clutch I can reuse the same ?
      I have a Tremec T56 six speed installed on my car
      Oct 2013
      Quote Originally Posted by NightRider12 View Post
      Another question:
      if it's a lt1 t56 your going to have to change the faceplate and input shaft to a ls style and I don't believe the clutch will work
