    Results 1 to 20 of 24
      Mar 2014
      Greenville, NC
      Truck/ Trailing Arms in my 97 C1500?
      Well, I've been on hiatus from the whole truck project for most of the summer but its about time to dive back in. I bought a Wrangler with a motor that dropped no.4 as a project to fix and fund the C1500 project. I've had lots of time to think about suspension an what I've got in mind for the next level of performance is ridetech strong arms up front and a custom coil over set up, Maybe a shock tower for more travel. The big question in my mind was what to do out back. I want to get away from the leaf springs. There lots of custom options and a couple of bolt in, but I'm thinking Truck arms with Ride Tech coilovers and of course a track bar set up. This requires moving the fuel tank to the rear of the truck. Not a bad deal, Blazer tanks cheap and its other wise bolt in for the most part. Now, as for truck arms there is a fella selling used NASCAR truck arms on Ebay, I think this could be a start. Any advise past that point on Geometry or is this just a crazy idea??? Any help or advise will be greatly appreciated.
      97 c1500 Sierra, getting prepped for LS3 TR6060 swap!
      Jun 2014
      Hey man Ive been watching your threads for a while, and have some very similar interests and I live right down the street and around the corner ( Im in greenville too) truck arms sound awesome i have a 85 c10 i just bout and plan on going the same route. Got a link for the arms on ebay, does he have multiple sets?
      Mar 2014
      Greenville, NC
      Yea man I've done a lot of thinking and researching and this is what I've kinda settled on.
      Do a search on ebay for nascar trailing arms. He has a few sets on there in different lengths.
      I'm right over on black jack Simpson rd. If you ever want to get together and kick some ideas around.
      Apr 2010
      State College, Pa
      Only thing I would watch for is the length of the arms, normally the left side is shorter from the nascar stuff to give the car a bit of "yaw" for side force
      Mar 2014
      Greenville, NC
      Thanks for the insight. Makes sense though. I'll have to pose that question to the seller. Although I'm guessing that could be easily solved at the cross member as it needs to be custom fabricated any how.
      Mar 2014
      Greenville, NC
      Scratch that last thought. Haven't had lunch yet today and my brain must not have been turned on. The length of the arms changes the radius upon wich the axle moves. Doesn't matter where it's mounted. I'll have to get the guy to measure and then reassess.
      Birmingham, AL
      There was a company called hot rods to hell that did truck arm stuff. Maybe you could retro a 60's-72 c10 crossmember in. They were truck arms.
      Stephen
      Mar 2014
      Greenville, NC
      I stumbled upon their website in doing some research. I just can't see paying a bunch of money for parts I'll have to modify to work when I can fabricate the cross member and track bar. All that said I could also fabricate the trailing arms but feel like I want to start with some part in hand to start with, in this case the arms.
      Mar 2014
      Greenville, NC
      Double post. Figure no body wanted to read the last post twice.
      May 2010
      Mooresville, NC
      Check with Roush Yates Performance Parts in Mooresville NC. They have a huge selection of used Nascar race parts and everything is priced right. If you are ever in NC, they are worth stopping by for a visit.
      Marc Battiste
      1969 Camaro
      LY6/T56/12 Bolt
      Mar 2014
      Greenville, NC
      I'll have to do that when I get out that way. I'm in eastern NC. I want to make it over to good guys this weekend for a bit, I'll have to play it by ear though. I never know when I'm gonna get off work on Saturdays.
      Jun 2014
      I wanted to go to the good guys show too but new job :( oh well got make money to buy truck parts
      Aug 2010
      now In Dandridge, Tn.
      Some of the outcome may depend on the desired ride height. We spent a lot of development time a few years ago on trailing arms for F-100s and 55-59 chevys, and then scrapped the idea. For the T.A. to deliver performance, the front mount, (which sets the I.C. and the Anti-Squat) needs to be above the axle center line. (we don't get slicks and big aero down force like the Cup cars) As the truck gets lower, the front mounts gets pretty high on the crossmember (see Hotchkiss C10 mounts), then, with the mounts wide on the axle, and the narrow 34" frame, the T.A. starts to hit the bottom of the frame. You can use blocks, or bend the T.A. but these reduce the effectiveness of the suspension. You can also modify the shape of the rail to clear, as done on the 63-72 C10's. 47-54 chevy trucks are well suited for T.A. suspension, as the frame gets wider as it goes back, and has a higher kick. Wes D.'s 59 chevy was originally built with an aftermarket T.A. suspension, and it proved to be to restrictive. He has since removed the T.A. in favor of a 3-link, and is having much better results. - If the truck isn't going to be that low, then frame contact may not be an issue. Stay away from tubular arms and urethane bushings. Both restrict axle rotation. O.E. style H beams with bearings or rubber work best, or fabbed tubular arms with pivoting adjusters. Hope this is of some help.
      Feb 2010
      For ride and handling, I'd go Corvette C4 IRS. It almost installs itself on our trucks.
      http://www.sporttruck.com/featuredve.../photo_08.html
      Mar 2014
      Greenville, NC
      Hey Rob thanks for chiming in. Love your work. In fact I was on your site checking out a few of your products. Currently my truck has some rake to it and I would like to level it out, so I would have to drop the rear some. I'm not tempted to go any lower in the front though as my chin spoiler already hits curbs every now and then. I have belltech c notches installed and I'm sitting what seams to be mules from the bump stops at current ride height. I'm gonna do some initial measuring this week and see how I think things will shake out. The other idea I had in mind was to build control arms that would mount in the spring pockets and attach to the rear end and run a cross member for a 3 link set up. Of course with a track bar. I've just got to do some measuring. I tried to make a bad lowering leaf that was already installed when I bought the truck ride better but I'm tired of bouncing down the road and want to try and do this only once more and hope like heck it performs.
      Mar 2014
      Greenville, NC
      Quote Originally Posted by ccreddell View Post
      Funny you should say that!
      Mar 2010
      I've been following this thread with interest. As a 67-72 owner, I have the trailing arm suspension you are considering and will NOT move forward with that design in the next version of my truck.
      Given the massive amount of work, and total lack of space for exhaust - why not put in a 4-link or even a 3-link? loads of adjustment, tough, proven, cost effective.
      Am I missing something?
      Mar 2014
      Greenville, NC
      You may be very right! That's why I put it up for discussion. There are many options but nearly all are gonna require some fabrication with the exception of the Airbar and chassis works bolt in 4 link. I'm thinking about a 3 link set Up. It may allow me to run my factory fuel tank, but I'm seriously thinking moving the tank to the rear (blazer tank) would give me the best balance and better handling any how. A quick look today and I think I could follow some the bolt in 4 link kits out there for cars that are on the market and use the factory spring pockets and run my arms back from there. At the ride height I'm looking for it should have the lowers nearly level. I'll know more when I pull the bed back off.
      Feb 2010
      Middleburg, NC
      I bought a '69 c10 rear end and TA setup so that I could put it under a 2wd S10 blazer. I am cleaning the TA's up and going to weld rod into the center valley the lentgh of the arms to stiffen them. If a 3400lb 900 hp cup car can run at Watkins Glen and Sonoma I don't see a 2700lb 450 hp blazer couldn't make good use of TA's with jack bolts.
      Lee Wiggins
      I once had -
      1967 Camaro, 1972 Chevelle, 1969 RS Camaro, 1987 T/A GTA, 1991 5.0 LX Trunk, 1951 & 54 Chevy Panel Trucks, 1950 Ford F1, 1964 Chevelle SS, 1965 Chevelle 350 4spd
      Now I drive a 1990 K5 and a 98 Accord. :bsjerk:
      Working on project "Rosie" '87 C-10 shortbed stepside!
      Jun 2014
      Ease of setup for TA is the most appealing thing for me. In my case the truck will rarely see track time just lots of play on country back roads. Got any pictures showing exhaust complications?
