      Replacing a powerglide
      Does anyone know what tranny's are the same physical length as a 2 speed glide? I would like to replace it with a T-350/400 or OD trans.
      Thanks!!
      Jul 2002
      Mesquite, TX
      TH350 should be the same length and same mount points.
      th350 was a direct bolt in for my 68 Camaro.
      May 2002
      Northern California
      If this is for your BOP, 400's are alot easier to find...ask me how I know! LOL
      A 350 would be an easier swap but...
      There are another set of bolt holes to mount your trans crossmember back farther.You'll need to get a shorter drive shaft and mount and wire in a kick down switch. We had an easy swap cause we found a donor car in the wrecking yard.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Oswego il
      what kind of shifter are you going to use, ive got a horseshoe shifter that was used in a p/glide to th350 swap, you just have to notch out a section to get to 1st gear. pm me if you want pics.
      My shifter is a column shift. If I have to do some mods, I may just go with an OD trans to make it worth my time and money. Is there an OD that would be a bolt in without much mods?
      May 2007
      411 from the interweb:
      "The 200-4R overdrive trans has a 27-spline TH-350-style output shaft and is commonly found in ’81-’90 Chevy Monte Carlos, Malibus, El Caminos and Impalas. These transmissions are durable enough to withstand the punishment of the legendary turbo Buick Grand National from the factory. The 200-4R measures 27.75 inches, with a 26.81-inch mount position. To swap with the ’Glide, the crossmember must be moved back 6 inches. The good news is that the driveshaft will not have to be shortened."
      http://www.drwtransmission.com/thm_200-4r.htm
      Mar 2002
      Redwood City, CA
      Yup. The 200-4R is the same length. I used the same driveshaft with no modifications when I swapped it in for my th350. The mount is quite a bit further back though.
      Allen Ortega
