    Results 1 to 20 of 21
      Jun 2010
      Deployed
      Sway Bar Reccomendation for Quadra-Link
      There is a 1" bar and a 1-1/8" bar. Which one are most of you using and why? I know through the searches, DSE didn't use to have rear sway bars for the Q-link.
      Nov 2013
      near Charlotte, NC
      1.125".....really depends on rest of suspension combo.
      Original owner '84 Grand National. CAS V1 (big) front-mount intercooler, Comp roller hyd cam, Champion Al intake/heads, T66 turbo, 3.5" custom cat-back exhaust, RideTech TruTurn front & DSE rear swaybars/ctrl arms, Ridetech 3-way coilovers, Baer 6P 14/13. FAST w/TouchScreen & GM Flex Fuel sensor, 120 lb injectors, Ricks SS tank, Aeromotive Eliminator pump.
      Aug 2012
      Southern Oregon
      What size if any do you have on the front? Rule of thumb is at least one size smaller on the rear.
      Wake Forest,NC
      I bet I've only connected my rear bar 3 times, I would stick with the smaller bar.
      Jun 2010
      Deployed
      I know this is old, but I forgot to buy the bar, now I'm about too. I have the DSE frame, what is meant by one size smaller?
      1970 Camaro/DSE build
      Pittsboro, NC
      You typically want to run a smaller bar than the front. So if you have a 1.125" in front, use 7/8-1"in back.
      Jun 2010
      Deployed
      Quote Originally Posted by JayBird View Post
      Makes sense, but the sway bar is not round on the DSE frame. It's like a splined arm,
      Apr 2015
      This is goos stuff to know. I was gonna go with the 1.125" rear to match the front. Is this going to lead to massive oversteer?
      I'll be using 325 or 345 tires on 19" wheels on the quadralink.
      May 2006
      Barrington, IL 60010
      Depends a lot on the rear spring-rate. Big springs/big bar...no bueno! Ask me how I know.
      Rich
      'Wicked Witch'...1969 Camaro, Mast Motorsports LS-3, Magnum T-56, DSE suspension & BFG Rival-S on Forgeline wheels.
      A herd of stock #'s-matching '69 Camaros.
      Sep 2008
      There should be a bar going across the frame that the splined arms attach to. The arms themselves are just attachments to the sway bar.
      Apr 2015
      Quote Originally Posted by lzdick View Post
      Lz, what are u calling big? I'm gonna have 650# front springs and the rears on the quadralink are the standard 250. What are u running?
      I have a 1 5/16" front sway bar too. If the rear is supposed to be smaller than the front, is the difference between the 1.3125" front and the smaller rear of 1.125" enough? That's a difference of .1875 (3/16").
      Apr 2015
      Anyone have more answers for us?
      Beach Park IL
      Comparing the size of the rear to the front is pointless, rates are what matters.
      650# springs on what? DSE sub? If yes, you will want to up the rear springs to 350# or more depending on intended usage. The 1 1/8" rear bar works well with the softer springs though, but you really don't need it when you start adding roll resistance through the spring rate.
      Donny
      Wake Forest,NC
      I would even consider going higher in the rear, I'm up to 450# in both of our cars.
      You guys with first gen's posting set-up info doesn't really mean much. The bar combination on Deb's first gen is totally different than my second gen even though I have both cars sprung very similar. The first gen's like a lot more rear bar than second gens do, I have a 1.250 rear bar on hers, mine has a .750 rear bar that I rarely ever connect since it makes the car way too loose.
      Beach Park IL
      ....depending on intended usage.
      Donny
      Central CA USA
      I would contact DSE for a recommendation. Their rear bar has very long arms so it should be softer than others of equal diameter.
      Jun 2010
      Deployed
      Quote Originally Posted by David Pozzi View Post
      I have been preoccupied I forgot to call them. I'm pretty sure the rear springs that come with the Qlink are 250lbs. The instructions don't mention any spec'd for the DSE frame bar or reccomendatons for a rear.
      Jun 2010
      Deployed
      I procrastinated, I think DSE is closed for the long weekend. Can I go wrong with the 1-1/8?
      Apr 2015
      I went with the 1 1/8" per DSE's recommendation. They told me they sell way more of it. Not sure if drag guys are using them or what though. I figured I would trust them. I may not even hook it up sometimes.
      Jun 2010
      Deployed
      Quote Originally Posted by Schroeder View Post
      What kind of car do you have?
