      68 Camaro Drop Spindles
      Well guys I'm not sure what happened but I listed this once before and had a couple reply's before the website had technical difficulties and now it's gone..so let's try one more time. I've alread lowered my camaro 2" in the front with coil spring but it's not low enough. I was thinking of going with some 2" drop spindles but I need them to work with 69 single piston disc brakes. Heidt's and Fatman Fab both make spindles that will work. I was wondering which if either is the best, or possibly any other company's that make spindles which will work for me?? Also, ar there any drawbacks to the drop spindles. Thanks
      nobody else??
      and by the way, the car has 18x8's in the front with 235/40/18's
      Central CA USA
      I think I posted a pic of a tie rod end hitting a wheel, just imagine your present tie rod ends two inches lower relative to the wheel.
      How much ground clearance do you have now?
