    Results 1 to 12 of 12
      Dec 2012
      Fuel System for Supercharged LS7
      OK, need some advice here ...
      I started looking at different fuel systems for my E-Force supercharged LS7 going in my 69' camaro, and want to do this right 'the 1st time'
      Question is, for a non-track street car, will the Aeromotive Phantom tank system be adequate, or should I consider moving up to Rick's vaporworx tank ?
      Also, fuel lines .. 1/2" (8AN) feed with 3/8ths (6AN) return ?
      http://aeromotiveinc.com/products-pa...lth-fuel-tank/
      http://www.rickstanks.com/vaporworks-tanks.php
      Steve
      Build it right ... 'The 2nd Time !!'
      69' SS/RS X11 PRO-TOURING E-Force LS7 - SOLD
      2 Custom FJ40's -SOLD
      77' 911 Hotrod - SOLD
      'Killer Piggy' 73 FJ55
      67 Camaro - TBD
      Apr 2012
      Woodstock, IL
      What's the horsepower? If you're going to be over 700hp the phantom 340 will be maxed out. Someone posted a pic that Aeromotive is coming out with a dual pump system soon which would be adequate for your build, not sure when though. Or just go with the Ricks!
      -Dale
      SchwartzPerformance
      Dec 2012
      Thanks Dale
      Manny (Dasilva Motorsports) estimates approx. 650 at the wheels so ...
      It's not really the supply that worries me, it's more the heat issue and the supporting electronics behind it that concerns me (reading about Rick's vaporworx)
      67 Camaro - TBD
      Oct 2006
      Michigan
      walbro 450 fuel pump will support that. Its also e85 compatible and boost loves E
      Apr 2012
      Woodstock, IL
      You can get the TanksInc tank (same tank as Aeromotive) but with an internal Walbro like fast98 pointed out. If it's just a street car you won't have any fuel starvation issues where you'd really benefit from a vaporworx setup. Just a thought!
      And I'll pitch were a Tanks Inc dealer
      -Dale
      SchwartzPerformance
      Jan 2014
      Seattle WA
      The Aeromotive 340 Phamtom will support up to 700hp on a boosted EFI application. Sounds like that will be just fine for you. If not, they have a new 450 pump coming out at SEMA. No need to buy an EFI tank if you want to use your stock one. The Phantom kit takes care of that.
      1967 El Camino 408ci LSx....and the build begins!
      1967 Turbocharged 408ci LSx Chevelle - 1012 rwhp, 959 rwtq 67 Chevelle
      2009 Supercharged Silverado - On the Dyno
      May 2013
      Wouldn't the 700 hp rating be at the crank? 650 hp at the wheels would likely push past 700 hp at the crank.
      Apr 2012
      Woodstock, IL
      Correct.
      That's at least 750 engine hp.
      -Dale
      SchwartzPerformance
      Jan 2014
      Seattle WA
      Quote Originally Posted by blu72nova View Post
      That would depend on the transmission used.
      Dec 2012
      Thanks for all the input guys !! Trans is going to be T56 Mag
      Looks like it's going to be the Tanks Inc. with the Walbro 500 -1000 HP internal pump
      Steve
      67 Camaro - TBD
      Jun 2010
      Commerce MI
      Steve,
      I am interested.. How did this fuel tank set-up work for you??
      May 2010
      kitchener,Ontario,Canada
      I wish I paid attention when I was at the shop and checking the car out. I can't remember what he used but I definitely should have paid attention being as I also will be getting the boys at dasilva motorsports to build my LS7 na thou
      Ryan Austin
      On Instagram ryanaustinss70
