      Jun 2010
      Commerce MI
      LS3 416 cam specs????
      Folks,
      Need opinions, thoughts on Cam specs.. Going into LS3 416, being built from ground up.. Looking at Comp Cams #54-474-11. 251 intake/267 Exhaust 115 Lobe
      Mainly street car.. Will do some track days/autocross. Want driveablitly on the street.
      Wake Forest,NC
      I would go a little more conservative if drivability and street is the primary use. I had this one in my LS7, pulled well off idle and mid-range http://www.compcams.com/Company/CC/c...csid=1411&sb=0
      Mar 2010
      Okinawa, Japan
      If you're building a 416 LS3 from the ground up I'd have a custom cam spec'd. It's what $50 more than an off the shelf grind in a $8-10K build and you can get exactly what you want for your specific combo.
      Just my $0.02
