    Results 1 to 19 of 19
      Jan 2009
      LT1 T56 Clutch Problems
      Trying to get a handle on what can be wrong with my clutch/hydraulics. I have 5K miles on my t56 swap with EVERYTHING being new, hydraulics, clutch, t bolt, fork etc and the clutch is officially smoked. From day 1 anytime I was backing out of the driveway or moving it into the garage where you never get to fully engage the clutch, it would make a wurring sound (I have a video I will upload later) and then will smell clutch. Ram told me thats just the clutch breaking in so I didn't think much of it, but it has never stopped. Also when driving the car hard in between shifts I smell clutch. The clutch does not engage (if its even fully engaging) until the pedal is almost fully out. It’s about 1 mm left on the throw before it actually engages. Any ideas of what I can check before I pull the trans.
      I think 1 of 3 things can be happening:
      1. For some reason the clutch is not fully engaging (the LT1 clutches are pull style) so therefore when its "engaged" the pressure of the PP forces the tob closer to engine, that moves the fork that pushes the piston of the slave cylinder in (toward the back of the motor).
      2. The fork is not lined up on the TOB and when the clutch is pushed in its only grabbing some of the PP fingers.
      3. The bolts of the PP are not torque properly allowing the pressure on the clutch disk to be more in places than others. VERY unlikely. I am OCD about torque things properly and making sure things are tight.
      Other than that sound and the fact that my clutch is done after 5k miles there are no other noises. Also, other than that problem there are no other drivability problems. The stick moves easily when going between gears meaning its fully disengaging.
      I wonder if its not fully engaging since my car engages so far out on the clutch throw, maybe the clutch is riding between the engage point and disengage?
      Sep 2014
      I have been reading about making the clutch master rod adjustable and seem to remember many people saying it fixed this very problem. Do a search on it. What car is it in? What hydraulics are you using, GM, Tilton? What pedals did you use? Who did the swap? You? Did you do the clutch arm and push it into the throwout bearing personally? What is your pedal ratio? How much travel does your pedal have? Is the pedal hitting the floor or is it stopping in the master? How far down on the pedal is it? Is it traveling in a deep arch or is it moving in a very straight line?
      Jan 2009
      Its seems as though you are talking about the guys who have problems with over extending the slave and hearing that grinding sound which is the clutch fork grinding on the pressure plate. I DO NOT have that problem. Thats why they modify the master rod.
      1988 iroc 350. Did the swap myself. Stock 3rd gen pedals. I have a set of 3rd gen pedals that I modified to have the master pivot more like the 4th gen pedals. I may install those and see how the engagement is, what do I have to loose, the clutch is shot as it is.
      Brand new GM hydraulics.
      I did the swap.
      Brand new fork and t bolt EVERYTHING IS BRAND NEW.
      I have taken the clutch for off and pushed it onto the TOB myself numerous times. I don't see how you could possibly screw that up on a LT1 t56. The fork has a taper and slides right on and snaps into place at the t bolt.
      The pedal hits the floor but there is still some movement on the rod so its not maxing out the master.
      The arch is not bad at all, in fact I did a huge write up a few years back when I first installed the t56 to see if I could get the clutch to engage more like 1/2 pedal throw, I will see if i can find the post.
      Jan 2009
      Aug 2012
      Peoria, AZ
      It sounds like to me that you are having a pedal travel restriction that is not letting the pressure plate fully engage the clutch, which is unusual because most of the issues with a setup like this go the other way and have too much travel which lets the clutch fork get into the pressure plate when the clutch pedal is pushed in.
      Can you shorten the rod between the pedal and the clutch master any to test if this is the case? You are using F-body hydraulics correct which is a sealed system so nothing to adjust there. Heck, just take the clutch master push rod loose from the pedal and see if it pushes out further.
      When my clutch is all together and I take the slave cylinder bolts loose, the pressure plate will push the block between the slave and the bellhousing out about an 1/8" or so before the tension is off. How far does yours push out when you loosen just those bolts?
      That is the only thing that I can think of that would be restricting the pressure plate from fully engaging the clutch unless there is something internally wrong with the PP or clutch disc itself. You are using a LT1 specific flywheel correct? They are way different than any other flywheel. And do you have a 1 piece rear main seal and the proper flywheel for that as they are different than for a 2-piece rear main seal block.
      Lance
      Jan 2009
      Jan 2009
      Yeah, I have checked that. The pedal is not contacting anything so that allows the master to fully extend. I have never pulled the master off the pedal, maybe Ill check that but I dont think thats the problem.
      My slave when installed into the fork (in fact I hooked it back up yesterday after checking things) the slave needs to be pushed a bit to get the nuts to start. This is obviously without the zip tie that held the piston in while new. So i guess there is quite a bit of preload on the fork while at the engaged point, but it takes a good deal of pressure to push the fork so i don't think its slightly disengaging the clutch.
      How far should the fork be out past the bell housing....mines about 1/4 according to my calculations.
      I have some pictures I can post to see if anything looks wrong.
      Jan 2009
      Aug 2012
      Peoria, AZ
      My clutch fork is just about flush with the bell housing where it looks like yours is sticking about a half inch out. That is where the problem is in my opinion, seems to be too much preload on the clutch fork. I don't know why though. I can slide my slave on the bolts all the way to the adapter and only have to snug it down with the nuts the last 1/8" or so.
      It has to be flywheel related, maybe not thick enough letting the pressure plate get too far away from the trans and screwing the geometry up. when you tighten the slave cylinder nuts up it is slightly disengaging the clutch which will kill it in a hurry and also screw the pedal travel up.
      Lance
      Hildebran, NC
      .....My clutch fork is just about flush with the bell housing.......
      ........ It has to be flywheel related......
      I just put a clutch in my car yesterday, and my fork is flush to the bellhousing as well.
      I would double check the flywheel while you have it apart.
      Call McLeod or Centerforce and see what the distance is from the crank flange to the face of their units, and compare.
      Good luck.
      Jan 2009
      Quote Originally Posted by rchaskin View Post
      Good luck.
      I guess its possible its a bad flywheel or out of spec, but I checked the part number and the flywheel is intended for a lt1 camaro. IIRC its a zoom p/n that i got from napa.
      Jan 2009
      So your saying you can put your slave on without that zip tie and it will push all the way to the slave spacer without having to muscle it????
      I trust what you are saying and found it odd that a system would be designed where you had to muscle the slave into place and made me think my fork was too far out. I do find it hard to believe though that the slight preload of the slave rod could push the fork enough to keep it in a state of slightly disengaged.
      There are a few posts where guys running ram clutches had clutch disks that were too thick. I wonder if thats my problem.
      Either way it looks like its time for a new clutch.
      Aug 2012
      Peoria, AZ
      Quote Originally Posted by camaro1185 View Post
      Your problem seems to be that your throwout bearing is too close to the engine in a static state, not too far away from it...when you tighten down the slave cylinder nuts you are pulling back on the throwout bearing releasing the clutch slightly.
      Lance
      Jan 2009
      its a stock l98. 1 piece rms. I just went to napa and had them get me a stock replacement flywheel for a 96 camaro (thats the year and make car the t56 came from )
      I suspected the wrong flywheel but checked my part number and it is correct for that car.
      Aug 2012
      Peoria, AZ
      Yep, it'll slide almost all the way on, just need to snug it with the nuts the last 1/8" or so. You never answered if you have a 1-piece rear main seal block or 2-piece rear main seal. Also which flywheel do you have? There is a very specific (and expensive) flywheel for a 2 piece RMS block to work with a LT1 style clutch. The 1-piease RMS flywheel is a bit more common and the two WILL NOT interchange.
      I still wonder if you have the wrong flywheel for your application?
      Lance
      Aug 2012
      Peoria, AZ
      Clutch fork bent?
      Which Ram Clutch kit did you purchase? I'm running the Power Grip Clutch Set GM LT-1 Sku: RAM98516
      Lance
      Jan 2009
      Clutch fork bent?
      No, and honestly is that even possible, that thing is BEEFY!
      Ram HDX.
      What I have read is ram clutch are hit or miss. Do a search there are some people who have gotten no more than 6K miles out of the clutch. It seems the 2 most common problems is a clutch that is too thick over all, too thick and not even all around and having the springs break from the hub.
      Aug 2012
      Peoria, AZ
      Ram HDX.
      Your problem is the other way around...the clutch or the flywheel is too thin.
      Lance
      Jan 2009
      Yeah I figured as much. Assuming the T bolt I bought brand new is the correct length.
