      Orange County, CA
      Question about steering u joint
      When using the borgeson steering column u joints, are you supposed to drill a recess into the colum, dd shaft and gear box splines for the set screws? Or do you just tighten the set screws and call it a day? Thanks.
      Chesapeake, VA
      I would ABSOLUTELY drill a depression into the steering shafts where the set screws tighten. By doing so you at least have a fighting shot at catching the problem should a set screw loosen. Without that the possibility increases dramatically for something to come completely apart before you find and fix the issue.
      Cars are meant to be driven.
      John B
      Apr 2012
      Woodstock, IL
      Yep, what he said. A dab of blue Loctite doesn't hurt either , in addition to the jam nut.
      -Dale
      SchwartzPerformance
