      Jun 2014
      Rear sway bar modification question
      Over my head here. I have a 1969 Mach 1 that had a narrowed rear end swapped out for full width rear end before I purchased. It is tubed and still has springs narrower than stock I purchased an adjustable rear sway bar and it is roughly 2" too wide to install. Everything seems like it would be fine if bar was 2" narrower. Now do I cut bar and reweld. Reweld with short sleeve welded over cut or heat and bend to fit. Any suggestions would help
