    Page 9 of 12 FirstFirst ... 4 5 6 7 8 9 10 11 12 LastLast
    Results 161 to 180 of 223
    1. #161
      Oct 2015
      Thanks Josh!
    2. #162
      Feb 2013
      No problem!
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    3. #163
      Feb 2013
      She went under the knife this weekend (for many hours). I spent Saturday and Sunday taking the inside apart and tigging in the Wolfe Racecraft cage. I made a couple of modifications to make it fit the way that I wanted but it was a really nice kit. The new carpet and rest of the interior will be in shortly but I wanted to throw these pictures up while I had the chance. While I had the grinder/welders going, I finished putting the Stiffler's FIT system on. Like a typical fox, my frame rails/pinch welds had been used as jacking points in the past, which made more work for myself. After bending the pinch welds back into place, I was able to get everything tacked into place and finish welded on. This car should be extremely solid now! I'll get more pictures of the Stiffler's system when I get all of the welds painted up. It's an unbelievably nice kit.
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    4. #164
      Indiana
      Looks good Josh!
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
    5. #165
      May 2014
      Evansville, IN
      very nice!
      1967 Chevy SWB Stepside C10....6.0/T-56, Porterbuilt Level 1/Stage 2 build in progress
      2009 Acura MDX Sport...DD
      2000 NBS Tahoe...dog taxi/beater
      Sea Ray 200BR....taking up too much room in the garage
    6. #166
      Feb 2013
      Quote Originally Posted by Yelcamino View Post
      Looks good Josh!
      Quote Originally Posted by slowcpe View Post
      very nice!
      Thanks guys!
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    7. #167
      McKinney, TX
      Awesome!
      89 Mustang "Box Wine"
    8. #168
      Feb 2013
      Thanks bud!
      And some more updates!
      The Stiffler's FIT system is on the car, the cage is done, and the car is SOLID! *I'll be painting the cage and putting the carpet back in it over the weekend. *If everything goes as planned, the car is going to Cincinnati to get painted at the end of next week :D. *I'm getting excited guys.....
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    9. #169
      Apr 2015
      SoCal
      Those subframe connectors look AWESOME.
      CAM-T Autocross Fox Mustang
      LX mustang autocross on the "cheap"...
      1953 PickEmUp
      1953 Chev Pickemup
    10. #170
      Sep 2013
      sw Kansas
      Please explain the engineering in the under car bracing.
    11. #171
      Feb 2013
      Quote Originally Posted by LERM View Post
      Thanks man! I hadn't put subframe connectors on the car just yet so I ended up using the whole Stiffler's FIT system. Now that the car's tied together and running our suspension setup, it should be an animal in the corners!
      The setup that I put on the car was 3 different pieces: Subframe connectors, 2"x1" tubing along the pinch welds, and the bracing in the center
      The fox body cars are extremely flexible so the subframe connectors are a must, they tie the front and rear together. The pinch weld stiffeners are something that I can use as a jacking point now (the car never really had a good spot for a jack). The bracing welded between the two is just added strength that would also be helpful in the event of a side impact.
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    12. #172
      Jun 2014
      Highland Village, TX
      Quote Originally Posted by Josh@ridetech View Post
      Can I have your OLD Paint....lol Can't wait to see it Look Even Better, if that's possible.
      Ron -
      1970 Mach1
      440 RWHP, 428 RWTQ
      Calypso Coral, 357W, T5Z 5-speed,
      Edelbrock 454 17x8 Wheels, 255x40x17 rear, 215x45x17 front, Bridgestone Potenza RE-71, TCP Coilovers Front, Global West Del-A-Lum Bushings,Global West Adj. Strut Rods, Wilwood Discs All around
    13. #173
      Feb 2013
      Quote Originally Posted by Mach1_Ron View Post
      Haha, it doesn't look awful but I've had to buff, buff, and buff some more to get it where its at. There is some clearcoat peeling off in some random places that I want to get fixed. While I'm in the build process, I thought I'd go ahead and get it over with! I appreciate the good words!
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    14. #174
      Feb 2013
      Just an update!
      I've been playing around with a few things. I'm doing away with the rear seat and making a new floor (will be carpeted), re-did the battery wiring/chassis grounds, and made a battery mount to put between my spare tire well. I never have liked the battery boxes mounted on the corner of the car but for what I'm doing, centering the battery won't hurt my weight distribution too bad . I've got the cage all painted, put the new carpet in, installed the new ridetech harnesses, and put about 50 miles on it in the passed couple of days. I've got a couple issues still making me mad but it is what it is! I'll get it taken care of!
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    15. #175
      Apr 2015
      SoCal
      Those harnesses look killer. How long before there is a cheeto's dust thumbprint on that ridetech patch?
      What shifter handle is that? I'm needing a longer one to better match my seat position.
      1953 PickEmUp
      1953 Chev Pickemup
    16. #176
      May 2009
      Connecticut
      Josh great job. How do you like the Corbeau seat?
      Aldin
      1969 Camaro (Weapon of Choice) in the works
    17. #177
      Feb 2013
      Thanks man! I hope there's never a Cheeto's thumbprint on them! If there is, it'll come from my 3 year old crawling around in the car! Lol
      That's exactly what I was looking for when I bought this one, it's the perfect height/angle (and it feels alot stronger than the typical Hurst shifter). This one is from Bowler Transmissions.
      http://bowlertransmissions.com/p/433...56-magnum-t-56
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    18. #178
      Feb 2013
      After a lot of prolonged work, the car is at the new house. I found my issues with the car sucking oil through the PCV and spitting it out of the air filter. My own fault...I forgot to put the PCV splash guard on the lower intake so it was getting a direct feed of oil right through the vacuum lines. Pulled the lower and put the correct pieces on, put on a new vented catch can with AN fittings going to the valve covers, and got it running again yesterday. I also got the upper intake powdercoated as well.
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    19. #179
      Sep 2015
      SW KS
      Everytime I pull up your thread, I go straight back to corral.net and start looking the classifieds for another Fox. Your car looks great man.
      Chris
    20. #180
      Feb 2013
      Quote Originally Posted by cbpldc View Post
      Chris
      Haha, good! I appreciate it man. I finally gave in and got it dyno tuned on Friday. I thought I had some other issues but the tune cured everything that I was having issues with!! Just a little 331, nothing crazy but it made 364rwp/355rwtq.
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
