    Results 1 to 10 of 10
      Oct 2010
      SLC
      Carb relocation - any one ever tried it?
      I'm toying with the idea of relocating the carburetor on a car I am building to resolve a hood clearance issue. I realize this idea may be a bit out there, but I have seen it done on draw through turbo applications, and was curious if it's ever bee done on an NA motor. Assuming I built an adaptor with smooth turns and plenty of cross sectional area, could this be done without a negative impact on performance or drivability?
      Obvious answers to this are: give in and put a hood scoop on the car, or get a different intake manifold, but I'm really looking for some technical thoughts on the feasibility of the question above.
      Input appreciated.
      thanks.
      Zach
      Apr 2013
      Knoxville, TN
      My concern would be a possible drop in effective vacuum from the intake. In a draw through application there is another source of force drawing the fuel/air mixture to the intake manifold which is not there on a NA application.
      1963 Chevrolet Corvair Pro-Touring Project
      1964 Chevrolet Corvair Coupe Rat Rod/ Patina Thing
      2012 Mazda 3 I Sport Sedan
      Mar 2004
      Mid-Michigan
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Nov 2011
      Long lonesome highway E. of Omaha (SW Iowa)
      My barely educated guess is that youll lose some throttle response from the added plenum volume.
      Dec 2009
      Carson City, NV
      be careful, fuel does not like turning corners....
      Oct 2010
      SLC
      Quote Originally Posted by ChevelleNV View Post
      based on your comment, are you suggesting there may be a potential problem with fuel pooling up at some location?
      Zach
      Oct 2010
      SLC
      Quote Originally Posted by astroracer View Post
      Fascinating.
      Zach
      Dec 2009
      Carson City, NV
      Quote Originally Posted by Zachalanche View Post
      Yes..remember fuel is heavier than air...the straighter the shot it is for the fuel to make it to the valve the better.. why do you think tunnel rams run so well... because the fuel doesn't have to turn any corners...
      Oct 2010
      SLC
      makes sense. sounds like at minimum I may be negating the benefit of having a high rise intake.
      thanks.
      Zach
      Dec 2009
      Carson City, NV
      thanks.
      Pretty much...
