      Nov 2011
      Long lonesome highway E. of Omaha (SW Iowa)
      Simple tank baffling suggestions?
      Im trying to swap the gas tank in my 65 Comet wagon to a tank from a 92-96 F-150, and Im looking for some simple baffling suggestions. It wont be a track car, but I dont want any fuel starvation issues should there be some... Eh... spirited driving. As it is now, I get a wicked stumble and can watch the fuel pressure drop accordingly when I get on it in a lower gear. The tank itself is essentially the same as the tank Im taking out, meaning theres no baffling what so ever. A box O fuel if you will. Will a simple corral similar to the one pictured maybe an inch and a half tall be enough to help?
      Jun 2005
      Lynnwood Wa.
      Yes, The Tanks Inc fuel pump will work.
      How ever if you are using a F-150 tank why not use the stock F-150 fuel pump.
      Name:  Ford F 150 Fuel Pump Module.jpg
      Or use the stock 65 Comet tank with a Fourth Gen Camaro/ Trans Am fuel pump module.
      One consideration is the fuel level sender.
      Do you know the ohm range of the Comet fuel gauge.
      Using the stock tank the original fuel level sender can be retained, so that the fuel gauge will work.
      Installing a EFI Fuel pump in a stock tank, retaining the stock fuel level sender.
      Oliver Shultz
      It's OK to giggle and snicker. don't laugh and point
      Nov 2011
      The stock pickup assembly wouldnt fit the bigger Mustang pump I have (Im planning for more power down the road). The pump you showed is completely different than mine, so Ill assume its from a front tank, where mine is a rear tank. Im not interested in the pump assembly I posted, just the sort of corral around the actual pickup.
      Nov 2011
      This is my frankenstein pump assembly and unmodified tank.
      20140806_205553 by d1802, on Flickr
      20140803_175339 by d1802, on Flickr
      Southern Indiana
      I have used greenlee dies and punched holes in a sheet of metal, leaving several at bottom, then cut sheet off leaving half holes.
      I then shaped the baffle, we then cut slots in the tank tapped the bent sheet into the slot, then re-welded the slots.
      Tada baffled tank. We made smaller holes at bottom and larger at top.
      So far its been working fine, no fueling issues and car will 60 ft in the 1.0x range.
      632 BBC, ID2000 injectors, Aeromotive pumps. Makes well over 1300hp with boost.
      I have pics, if I can find them.
      Lee Abel
      AFTERMARKET PERFORMANCE
      Feb 2011
      Indpls, IN
      Decurion
      Can't you mount a fuel accumulator from a F150? Like in this thread, http://www.fordmuscleforums.com/fair...fi-swap-2.html.Name:  fuel-res-3.jpg
Size:  53.5 KBName:  fuel-res-3.jpg
      Florida
