08-10-2014 #1
help - i'm sure i've missed something
when i purchased the car it had a ccp front disc conversion with new brake booster and prop valve the the standard rear drum in place
when i rebuilt the rear end i added a simple disc conversion and left everything as it was (worked great with no issues)
at this point in the story everything is fine..........
so it was time for new brakes up front and instead of leaving things normal i of course had to seize the opportunity to do it better.
i grabbed a big brake kit from ccp with c5 calipers and rotors - when adding the kit i also installed an adjustable proportioning valve in place of the old one
while installing the new valve i replaced the brake lines from master cylinder to the valve because i didn't want to add a reducer to every connection (i mention this because the new line is a smaller diameter than what was there and i'm not sure if it makes a difference or not)
i then gravity bleed the system, flushed out all the old fluid then had a friend over to do a final bleed
now i have no pedal and it pretty much goes to the floor (it is enough to stop the car but not at any speed over 10mph)
what did i miss or do wrong?
any help would be greatly appreciated!!
don
Don
Grace - 67 Camaro daily driver with upgrades along the way.
https://www.pro-touring.com/showthre...-Camaro-Driver
