    Results 1 to 16 of 16
      Aug 2014
      from ground up chevelle
      Does anyone know or seen a chevelle built starting with an art morrison chassis and an entire body from AMD. In the end it seems cost would be around the same and the car would be brand new. Thoughts.
      Dec 2008
      Detroit
      I believe you're thinking about the body's from Dynacorn? Those start at 14K and they are not complete. You could find a good complete car for that price and mount the AME chassis to it. I know its not new, but you're essentially paying 14k for a body firewall back.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Aug 2014
      I was actually thinking of going to auto metal direct and buying every piece new for the body. Then mounting it up to the chassis from AM
      Dec 2008
      Detroit
      Quote Originally Posted by protourchevelle View Post
      When you said in your original post "an entire body from AMD" I was under the impression you meant a body and not components. You can do it that way, but its probably cheaper and less time consuming to just buy a body that's already in good shape that may need a patch panel here or there. There are plenty of abandoned projects out there where the body work is already done and the owner just ran out of funds or motivation.
      Chris--
      Dec 2008
      Detroit
      Its projects like this that make me say its not worth building a body from scratch if you don't have too..
      http://detroit.craigslist.org/mcb/cto/4607662432.html
      Chris--
      May 2010
      kitchener,Ontario,Canada
      Regardless of that issue be aware here in Canada if you were to build a "new chevelle "....and not have a VIN number when you go to register it. You would be issued a "kit" car vin which means it then falls under the same rules and regulations as a kit car even though it's a 70 or whatever ever you make it. If you buy a "real " chevelle and do the body work its still a Chevelle on the ownership...etc etc etc. Now some people are basically buying just VIN numbers from cars being scraped allowing you to buy a new shell and then attaching the original VIN to the new body and being able to register it as a original chevelle as opposed to a "kit" car
      Does everyone follow lol
      Ryan Austin
      On Instagram ryanaustinss70
      Dec 2010
      Fredericksburg, VA.
      I have thought about a new body and an aftermarket performance frame. If you go the AMD route, also look into having the AMD Installation Center assemble the body. They have all the proper jigs to keep the dimensions correct and their prices are pretty reasonable.
      http://www.amdinstallation.com/
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Sep 2014
      Art Morrison chassis with full suspention is just short of $18,000 Ouch.
      Then a whole new body to?
      That's an expencive way to go... Sure it will be a brand new car but it'll be $150,000 when it's done.
      You can buy a hell of a nice car for that kind of money.
      Apr 2012
      Woodstock, IL
      We've sold body/chassis combos too as were a Dynacorn dealer.
      The cost is up there, sure. But as with any custom build, it's YOUR custom car. Not anyone else's.
      It's sometimes more cost effective to buy an original body that is in good shape so you get the window regulators, trim, dash and interior pieces.. Sometimes!
      -Dale
      SchwartzPerformance
      Jul 2014
      Canada
      Hi,
      My Chevelle needs new floors, the frame isn't in very good shape, and the only body panels in good shape are the rear quarters & roof. The 350 engine and TH350 are in good shape also, new carb/battery/wilwood power disc brakes, exhaust. Needs suspension to handle the way I want it to.
      In my case what would make more sense to do?
      Replace with new body panels/paint/frame or sell and find something else in better shape?
      I'm into the car for $12k (Canadian).
      I am on the fence and in need of experienced people's opinions.
      Apr 2012
      Woodstock, IL
      Quote Originally Posted by Paul Chevy View Post
      Hi,
      I assume you're having a shop do the work for you? It's hard to say.. Buying a different car & not seeing it without paint is risky since you may end up in the same boat as you are now. If all of your body mounts are rusted & you need new everything, then I'd say try and find something in better shape that doesn't need floors or full quarters. You said you're already $12k into the car though and you're likely not going to get that money back if you sell it..
      If you're using the stock frame and just want some bolt-ons, then obviously you'll need to find a new one. Otherwise we can provide our G-Machine Chassis with all new components.
      Tough call! Others will chime in.
      -Dale
      SchwartzPerformance
      Dec 2010
      Fredericksburg, VA.
      Again, If I were you, I would contact the AMD Installation shop and discuss having them restore your body.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      Sep 2014
      My build is still in process, but I have an AME frame and replaced the vast majority of sheet metal with AMD. The only original metal is the body skeleton and roof skin. Build thread is here:
      http://www.chevelles.com/forums/showthread.php?t=426265
      FYI - It will total me about half of the $150k previously mentioned.
      Apr 2014
      Salt Lake City
      My 64' has a Roadster Shop 'Fast Track' chassis and is incredible! handles like on rails and solid with all 800+ rwhp when I get on it.
      May 2010
      Hi,
      Don't know where in this massive country you are but if you do a ontario search on kijiji under chevelle....parts. there are 1-2 stock frames for sale usually around 1500$....
      Ryan Austin
      Feb 2012
      SW, Michigan
      That's a tough call, we have re-bodied a bunch of these cars and I like to see them saved but buying a chassis and new shell would surely speed things up.
