      Mar 2010
      Alabama
      DSE master cylinder
      I am currently installing a dse master cylinder and booster combo on my 69 camaro. I am currently building the car and I have started fabricating my new brake lines. I am building stainless lines because I like the look. I am building my own so that I can route them neatly and cleanly the way I want. Well on my 67 camaro with a wilwood master cylinder the ports are front to front brakes and rear to rear brakes. If I am not mistaking the old dse design was the same. I have started fabricating my brake lines when I was reading a forum and noticed the new dse design is front to rear and rear to front. So I called dse to ask because like I said I have started fabricating my lines backwards and I really don't want to start over. So the new design is front to rear and rear to front. My question is why? Is a bore size difference or does it really matter. I could not get a straight forward answer from the tech on the line because he didn't know but before I start over I want to be sure that it will not work properly as is...any help is appreciated...thanks
      David Butler
      "If you're not first, you're last"
      67 Camaro Twin Turbo SBC (changing from Blow-thru to Holley HP EFI)
      Inman SC
      DSE master cylinder
      I have the new design and instructions state front to rear and rear to front . Would be nice if someone would offered some nice lines pre bent for this setup .
      Inman SC
      DSE master cylinder
      Sorry must have read this elsewhere directions doesn't list ports in any order.
      Mar 2010
      Alabama
      They sure don't so now I have to remake my brake lines! Damn it haha
      David Butler
