      PRC Electric Fan instruction question?
      I am about to install my PRC radiator with dual electric fans in my 1968 Camaro but I am alittle confused on the instruction sheet provided in kit. I want to run the fans off the Fan Temp switch but the instructions only show a manual "Fan On" override switch wiring diagram.
      Instructions say:
      If you have multiple engine fans, and would like to have the option of turning them on separately with a temp sender switch for Fan 1 and a manual overrride switch for Fan2, use this setup. Keep in mind that activation of Fan2 is by manual overirde only.
      What is the benefit of having a manual override switch for Fan 2? I just want both fans to come and off as needed and not need to worry about a switch. I assume I can just run the two black wires from both relays to the Fan temp switch and be fine correct.
      Walla Walla, WA
      Correct.
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Jul 2013
      Hubert, NC
      The toggle switch is used as a back up if the fan temp switch fails. (it happens).
      David H. Amrine
      (USMC Retired)
      Boys drive fast on the street. But MEN prove how fast they are at the Track.
      Feb 2009
      muggy midwest
      That schematic is fairly basic. You don't HAVE to use fan 2 relay as a manual override-since it requires a ground for activation, you can simply use a 2nd temp switch. I prefer to use a single fan vs. two independent fans but if you are determined to run dual fans, I suggest running them in parallel any time they're on. It makes no sense to have one on, one off. We've come a long way in cooling efficiency since the late 80's.
      "...if at first you don't succeed, try again.
      If you still don't succeed, then quit-no sense being a damn fool about it..."
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
