    Results 21 to 40 of 46
    1. #21
      Nov 2012
      Arizona
      Awesome progress! I love the work that I have seen from the roadster shop and I would imagine their parts are just as nice.
    2. #22
      Feb 2012
      SW, Michigan
      That is sweet,, I have always wanted to put roadster shop parts under a project,, top notch stuff!!
    3. #23
      Jul 2014
      It's been a little while since I have posted some updates! We are busy getting ready to attend SEMA next week, but I am going to try and update you on our current projects!
      We have been working on the body work and a little fabrication along the way. We want to keep the "stock" look of this truck as much as possible, while still incorporating modern touches to make this truck an awesome driver.
      Stock tubs removed:
      Checking for tire clearance...and it turns out we have PLENTY with only widening the tub by an inch or so:
      And back to more boring stuff...body work. This is literally the only bit of rust that is on the truck...driver side door:
      Working on the hood:
      We are relocating the tank to the rear of the truck, so that left us with deciding what to do with the fuel door. We didn't want it to be in the bed like most others do because I didn't want to have to put the tailgate down every time I wanted to fill up (yes, I am kind of lazy). I wanted to keep the factory gas cap on the cab because I love the way it looks, but obviously it will be cosmetic only. Bob came up with a cool idea that we loved because it will keep the stock look of the truck and won't appear that we have two gas caps:
      It's just the rear sidemarker light when it's closed, but when it's open:
      Fuel door! The next piece we needed to take care of was the route of the filler neck. By putting the fuel door here, it basically takes a 90* turn straight down due to the bedside. This would make it a huge PITA to fill up because you would have to pump so slow in order for it to not back up and want to spit fuel back out at you. So we fabbed a pipe that takes the 90* angle out of it which will allow fuel to flow normally:
      We went with Forgeline DE3C wheels, 19s up front and 20s in the back. The finish is titanium centers with brushed outers...I LOVE how they came out. I think they are perfect! A little dirty in this pic:
      Now that we had the wheels, we needed to work on the front tubs. We wanted to keep the coverage to a minimum because we didn't want to hide the badass suspension pieces. Once again, Bob is working his magic and they are coming out awesome:
      For those of you that aren't familiar, there is a ton of empty space along the inner fender of these trucks. He took time to fill in a lot of the space to make it look like the tub is supposed to be there. It's going to look killer!
      The bed is just about ready for paint as well as the two doors, but I won't bore you with primer pictures. We did decide on Viper GTS Blue/Arctic White as the colors. Of course, we will be putting our own twist on the color.
      We are going to hit it hard once we get back from SEMA, so I should have more frequent updates. Here is a fun one to leave you with for now:
      -Lydia
      1970 C10 Project
      2002 EB Corvette Z06
    4. #24
      Feb 2014
      Oh that's just sweet!
      I love the fab on the filler neck, so cool.
    5. #25
      Jul 2008
      ohio
      the truck looks bad azz....
    6. #26
      Jul 2014
      Thanks guys...super excited about this one!
      -Lydia
      1970 C10 Project
    7. #27
      Feb 2013
      Very cool build!
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    8. #28
      Feb 2014
      Hanau, Germany
      Country Flag: Germany
      Very cool truck, Lydia. Which size wheels did you go with. You said 19s and 20s, but which width ? Also which size tires ? I see 245s in front, but which size in the rear ? You see many in the US still going with 18s. Over here in Germany 18s are becoming rare as all are going with 19s and 20s. Reason is that most super sports cars are having the larger wheels now. I was in Dallas just 10 days ago. Love Texas !
      Kai
      Hanau/Germany
    9. #29
      Aug 2010
      Yukon, OK
      wow. great work. is that a standard length rear end? how wide of a rear tire did you fit? thanks, Kenny.
    10. #30
      Mar 2010
      Clovis NM, 88101
      Its looking outstanding!!
      73 Camaro
      Gene
    11. #31
      Jul 2014
      Quote Originally Posted by Street-Garage View Post
      Kai
      Hanau/Germany
      The wheels are 19x9 in the front and 20x11 in the rear. The rear tires are 315/35/20 Nitto NT05Rs. We can pretty easily fit a wider tire as well...there is just so much room!
      Quote Originally Posted by okyankee View Post
      Everything was custom ordered from Roadster Shop, including the Strange 9" housing, so I cannot say for sure if it's standard width (for a 9") or if it's been narrowed. They have built a couple C10's with this setup before, so we went with what they used previously. The rear tire is 315/35/20.
      Quote Originally Posted by newmexicosaint View Post
      Thank you so much!
      I need to post some more recent updates. We have the frame completely boxed in now and have it (as well as the suspension components) back from powdercoat. It's a rolling chassis again!
      The cab and doors are scheduled to be painted this week and then we will set it back on the chassis so we can begin mocking up the turbo kit.
      -Lydia
      1970 C10 Project
    12. #32
      Jul 2004
      Braselton, Ga.
      Did you keep the 5x5 lug pattern.
    13. #33
      Jan 2015
      Charlotte, NC
      Always loved that color combo. We did the filler through the rear marker as well on my brother's '70, but used flex tubing inside the bed skin
    14. #34
      Feb 2015
      This is a very nice build and very detailed with the pictures keep em coming thank you and God bless.
    15. #35
      My 1970 C10 Build - Picture Overload
      Do you still have the 12 bolt?
    16. #36
      Jan 2013
      Nashville, TN
      Awesome build man. Love the color combo and fab work on this C10. Need to come check out the shop in Lewisville. We are good friends with Dusold who is not far from y'all. Will this truck make it to GoodGuys in 2015?
    17. #37
      Mar 2012
      Quote Originally Posted by chichirone View Post
      Ahem, the OP's sig says her name is Lydia .
      Most of the roadster shop stuff I've seen is C6 based, so probably that bolt pattern.
    18. #38
      Jun 2010
      Western Kentucky
      Any updates?
    19. #39
      Jul 2014
      Wow! It's been a very long time since I updated this thread. I must change that! It's coming up on 2 years for this build and I am getting SUPER antsy for it to be done...and it's almost there!
      The color we went with Viper GTS Blue (my favorite) and good old Oxford white.
      So, around this time is when we dubbed the name of this truck "Snowball". It just kept "snowballing" into more and more and...well you get the idea. The engine we decided on is a 376ci LSX block with MAST Black Label heads and a Brian Tooley turbo cam. The sheet metal Precision intake is literally a work of art and worth every penny.
      We also went ahead and installed a Wilwood master cylinder and Hydraboost system to help with the braking (I almost killed myself a few times with the drum stockers).
      Autorad makes an amazing brushed aluminum radiator support that we saw and just couldn't resist. It took about 10 weeks or so for them to make it, but it comes complete like you see here...awesome product.
      -Lydia
      1970 C10 Project
    20. #40
      Jul 2014
      Now it was time to start on the fun part...the turbo kit. One would think that there is a TON of room in the engine bay of these trucks, especially with a lot of the unnecessary "stuff" gone; however there is just barely room enough for a big Precision billet 88mm turbo and everything that goes with it LOL.
      Here we are testing the fitment of the turbo.
      Once we decided where we were going to put it, that's when all the fab started. So much work!
      Intercooler being mounted up
      Charge pipe
      Blow Off Valve
      Downpipe (yes it's 4")
      -Lydia
      1970 C10 Project
