    Results 1 to 1 of 1
      Jun 2010
      Arroyo Grande, Ca
      MSD HEI Digital conversion
      New Never Opened
      These MSD Digital GM high-energy modules with rev limiters allow you to adjust the rpm limit between 5,000 and 10,000. True high-performance modules built for HEI distributors, they produce 50 percent higher coil drive currents than the stock module. This saturates the coil faster, which gives you more spark energy at top speeds. The results are increased horsepower and rpm range, and improved starting. When used with MSD's HEI coil, these plug-in modules create a potent high-energy spark to 10,000 rpm. MSD's GM HEI modules replace all 4-pin modules used in HEI distributors with a vacuum advance canister. They can be used with factory, aftermarket, or MSD HEI distributors.
      80.00 + shipping
