    Results 1 to 14 of 14
      Jul 2014
      Wisconsin
      1970 Cutlass S Wheels
      I am building a car from the ground up body is off the frame so I really can't measure the wheel size. looking to see if anyone here has a 70-72 Cutlass and what size wheels and tries they are running with dimensions and pictures would be great.
      Dec 2008
      Detroit
      There are lots of different sizes out there that will fit a '70 Cutlass, what diameter wheels are you looking to run? I think you would be better off asking if "X" size wheels will fit?
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Apr 2008
      Virginia Beach VA
      I agree with Chris. Hard to suggest w/o some details provided on what you want. I'll throw out 2 options:
      mostly stock "appearing" without big brakes or lots of money on suspension upgrades - can't go wrong with 15x7 fronts and a 245/60/15 tire and 15x8 rears with a 275/60/15 tire. Will fill up both wheel wells and there will be no issues with tires rubbing or turning lock to lock.
      Big brakes and willing to spend $$$ on more expensive wheels, tires, suspension, brakes etc, I would suggest 18x8 fronts and 18x 10 rear wheels with 255/45/18 tires front and 295/45/18 rears or 305/45/18 rears with a little massaging and rolling the lips. These will also fill up the wheel wells nicely and with proper backspacing there will be no issues.
      Proper backspacing will depend on brakes used, suspension used, and rear end used.
      In my opinion 16" 17" and 20" wheels all cause issues that have to be worked around. That's why I prefer either 15 or 18.
      16" has very limited tire selections, 17" requires smaller sideway (with tire options available). Smaller sidewall is fine if you prefer that look but ride will be a little more harsh, 60 ft times will be slower at the track, but the car will corner better. Also if you lower the car so that the wheels "tuck" with the smaller sidewall you start to run into ground clearance problems with your headers etc. 20" with small sidewall are tall enough so you don't have to lower to give up ground clearance but you will pay a little more for everything and still have some of the negatives (see above) that come with smaller sidewall.
      It really depends on what look you like but this should get your started.
      -Joe
      Joe Lincoln
      Lime Green 71 Olds 442 Convertible
      Upgrades thread: https://www.pro-touring.com/showthre...ible&highlight=
      Nov 2001
      Quote Originally Posted by Shradezz70S View Post
      The Cutlass is virtually the exact same car as the 1970 Chevelle. We have fit many of those and we could help you out to make a decision. Call us 714.666.1999
      Brad Fanshaw
      Tech Line:714.666.1966
      bonspeedWheels.com
      Apr 2008
      Virginia Beach VA
      Quote Originally Posted by bonspeedbrad View Post
      Brad, I think that's true for the front wheels and tires and the width of the rear tire but I'm pretty sure a 70 Chevelle sits lower in the back than a 70-72 Cutlass or 442. For example if you put a 315/35/17 on the rear of a 70 Chevelle with stock rear springs it would look OK as is or maybe would need to lower the rear about 1/2" or an inch to tuck the tire a little. A 70 -72 Cutlass or 442 with a 315/35/17 rear tire will have about a 3" gap from the top of the tire to the top of the wheel well. Once you run 2" or 3" drop springs ground clearance for headers (for street driving) starts to go away fast. I think a stock 70 Chevelle likes a 26.5" rear tire and a stock Cutlass or 442 likes a 28" tire to fill the wheel well. I know they are both GM A body's but I think that's one thing that should be accounted for when selecting your wheels/tires for a 70 -72 Cutlass or 442. I should say that has been my experience over the years. I'm on my 14th 70 -72 olds and have tried many many different tire combos on my cars over the years. That's the reason for my suggestions in the post above.
      Joe Lincoln
      Jul 2014
      I would go with a larger wheel 18 - 20 looks better I think
      Jan 2013
      I'm running a 18x10 rear wheel on mines with a 295-35-18 tire I have no issues
      Oct 2017
      Hawaii Oahu
      Hi I have a 71 Old's cutlass s, I am running 17" rims all the way around, the rears I am running 275 x 40's I see your at 295's 35 and would like to go wider, you think 305's I would have issues? If not, it's nice to know 295's fit good, which I would be happy with too.
      Apr 2008
      Virginia Beach VA
      Quote Originally Posted by 71Oldsclassic View Post
      I have 305 45 18s on mine and it's really tight. Your BS must be perfect so the rim and tire are perfectly centered. you will have 1/2 to 3/4 " clearance max on each side so if your BS is off even a little you could have rubbing. On top of that I had to cut the wheel well lip on the inner rear quarter panels and I had the stock chrome trim ring rolled around that so you can't see where it was cut. Then I had to massage the inner wheel wells a little and put "flat spots" on my 3" tail pipes in a few places where the tires would hit during hard cornering. So....to answer your question - yes you can do 305s but be prepared to do a few light mods to make it work. Or...just go with 295s and as long as it's centered well you may not need to do anything. Also the less you lower the car the more room you will have. The wheel well get's tighter as you go up. That's the nice thing about 18s vs 17s you don't have to lower the car as much to tuck the rim - here's a few pics:
      Midas guy putting a "flat spot" on my 3" tail pipe for more clearance
      Joe Lincoln
      Oct 2017
      Hawaii Oahu
      Thanks for responding, your 305 looks awesome, fits really tight with your slight modifications. I'm just wondering is there a difference in wheel well clearance in Cutlass s and a supreme?
      Oct 2017
      Hawaii Oahu
      I also is running 3' exhaust
      Oct 2017
      Hawaii Oahu
      Are those 10" rims by 18"?
      Apr 2008
      Virginia Beach VA
      Yes they are 18x10s in the rear and no difference between the convertible/supreme body style vs. standard 70 -72 Cutlass or 442. I know several guys running 305s or even 325/50/15s with the other body style. 68/69s are different but the 70 -72s are all the same - It's all about getting that backspacing perfect. And your rear brakes make a difference. If you're planning on ordering rims with BS that fits a stock rear drum set up and then plan to buy big rear rotors, the BS won't be correct anymore. My BS with stock drums was 5.5 then had to change to 6 when I added the 12" rotors. Yours may be slightly different but for a 10" rim you should be in that ball park.
      Joe Lincoln
      May 2007
      Chicago, IL.
      Wheel Measurement Guide
      Here is something that will help with measurements.
      You can also download by clicking here: Wheel Measurement Guide
