    Results 1 to 16 of 16
      Jul 2013
      BMR Torque Arm Questions For The Pros
      I'm hoping that some of you that are much smarter than myself will look at this and answer my questions. I'm looking at this BMR torque arm with watts link setup.
      http://www.bmrsuspension.com/?page=p...535&superpro=0
      I was also looking at Speedtech Torque arm setup. Im leaning more towards the BMR kit due to the watts link. Looking for some confirmation this is a good choice please.
      Also... I'm wondering why on the BMR watts link arms they are bent and not straight? In the video they have online with the kit being installed in the 71 firebird the watts link arms are straight and not bent. When you look at the kit now and the install instructions on their website it shows the watts link arms bent. Is there a reason for this? Would this be a problem to be bent instead of straight? Something just seems off to me here, that's why I bring the question here to the professionals. Thanks!
      St George Utah
      What is the advantage of the Watts link?
      do you really need it?
      will it make a difference when considering what your intended use is.
      is it worth the added cost and added weight. over 100lbs?
      just specific questions to ask.
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      Jul 2013
      Trying to make me think ..huh?
      Im sorry, I guess maybe I should have been more clear.
      My question(s) was more related to BMR's bent watts link arms from a design stand point. Im not sure why they are bent as opposed to straight. And since they are bent does this create a problem?
      -From what I have read and researched the watts link keeps the rearend centered under the car better. I cant say for certain as I have no real experience.
      -I dont really "Need" anything different than stock. What it really comes down to is I "Want" something different!
      -Im not sure.
      -Added cost and weight as compared to?
      Thanks for the reply!
      St George Utah
      Thinking is GOOD
      well I certainly can not answer specifically as to why their links are bent I am sure you will have an answer very soon.
      The Watts Does keep the rear end from moving side to side in travel if it is designed and set up correctly, the panhard par in the Speedtech torque arm is long 31" so the side movement is minimal 1/8" total to the driver side through 6" of travel (3" each direction which is not even possible ) so the actual movement is closer to 1/16". Probably a lot less than leaf springs
      The added cost and weight was in comparison to our Torque arm.
      one other thing to consider is exhaust routing. out torque arm allows 3" over the axle, yes it must be custom built but this is the case for any aftermarket rear suspension.
      Blake Foster
      435-628-4300
      St. George Utah.
      Jul 2013
      Please look at page 11 in the assembly instructions. It clearly shows the watts link arms. This is where my questions came from as to why these arms are bent and if this posses a problem.
      http://www.bmrsuspension.com/siteart/install/TAS005.pdf
      Jun 2014
      braintree essex england
      Country Flag: UK
      keeping an eye on this post as I have ordered the bmr kit for my 79 should be here in England in 2 weeks
      Sep 2008
      Jacksonville, Florida
      It looks like they are bent to enable a lower roll center without the arms contacting the pivot. I don't see why this would be an issue in strength, most steering and tie rods are bent for clearance. When you draw a line from heim to heim, the linkage arms are at a pretty good angle. I was always under the impression the linkage arms should be parallel and level, but someone who knows more than me would have to comment on that.
      Craig Scholl
      CJD Automotive, LLC
      904-400-1802
      www.cjdautomotive.com
      "I own a Mopar, I already know it won't be in stock, won't ship tomorrow, and won't fit without modification."
      Hi there and Thank You for considering our Torque Arm Kit!
      The Watts Link Arms are Straight - the arms with the Bend are from the 1st Evolution of the Kit. We changed the Arms after the first few Kits went out (before my Time at BMR) and have been straight ever since. The Pictures have not been change which I apologize for and have been working to change.
      The Watts Link does keep the Rear End Centered and you can get a 3" Exhaust up & over.
      T.C.
      I'm available M-F 9:30am - 6:00pm Eastern Time
      Jul 2013
      Thanks for the info TC. So are the arms able to be parallel with the ground when everything is setup properly?
      It depends on how low the car is set-up. There are different attachment Points for the Arms. When you have one in front of you, this makes more sense.
      Jun 2014
      Country Flag: UK
      got my bmr kit today for my 79 trans am here in the uk. realy happy how well its made the welding is spot on and and its a chunky bit of kit. the only problem I have is there are lots of parts but no instructions but I could probably down load them does any one have a link please. I will let you all know how it is once fitted .
      Quote Originally Posted by KEV 190164 View Post
      I sent you a pm to see which Part # Kit you purchased so I can get you Instructions
      T.C.
      Jun 2014
      Country Flag: UK
      pm sent thank you
      No Problem! Any questions while installing the Kit, just ask me. Looking forward to you having it done and enjoying it.
      T.C.
      Sep 2007
      did you ever get this car on the road? thoughts on the BMR set up?
      You call me about these - I not only sell these (I'm our Torque Arm Guy) but I have kit on my '73 Camaro
