      Oct 2011
      2nd Gen Alignment specs
      I just installed a full ridetech single adj coil over System in my 1978 Trans am.
      Can anyone recommend something for an aggressive street car?
      thank you
      Jan 2014
      San Francisco, CA
      7 degrees caster, 2 degrees camber, and 1/32nd toe in.
      Jun 2006
      Katy,TX
      I assume negative camber there? Definitely can get near that with stock arms!
      1965 GTO project car
      2004 Pulse Red GTO
      Jul 2010
      Sacramento, CA
      Yeah negative. I'd just keep tossing in shims in the rear bolt till you got to 2 degrees negative, then get it even side to side. The toe in is gonna help it track straight.
      -James
      1974 Z28 SCCA C Prepared
      1990 Firebird NASA CMC
      1989 Civic Si SCCA STC
      Jun 2006
      Katy,TX
      My limiting factor with stock arms was them hitting the steering shaft at the rear !
      2004 Pulse Red GTO
      Jul 2008
      BATON ROUGE
      I use to run 5.5 caster and 1.75 camber and car worked pretty good.
      Tim B.
