      Jul 2012
      Mooresville, NC
      T-56 Magnum Issues Continue
      Hey team I was looking for some help on a T56 Magnum transmission that I purchased from Keisler Engineering prior to the bankruptcy. I have contacted the new company, silver sport transmission, and attempted the troubleshooting they asked with no luck.
      Problem: 50% of the time when I put my T56 in reverse, it will pop out of gear and make a slight grinding noise (assuming syncros) whenever I begin letting out the clutch. What is weird is that immediately if I try to put the car back into reverse it typically will go in gear and stay. Like I said this problem happens ~50% of the time which I cannot explain either. I put the DexMerc Auto transmission fluid in the tranny as specified by Keisler. It does have a hydraulic clutch which I have changed out the DOT3 fluid and replaced with DOT4 and then bled the system (this was recommended by SST). All other gears shift smothly with no issues.
      Question: Has anyone else experienced this problem? This didnt start immediately when I started running the transmission, it only started after I took it to the body shop for some touch up work. I was wondering if there way a way the body shop guy could have bent a clutch fork by not pressing the brake and allowing the reverse lockout to engage? I have verified that the reverse lockout is properly working.
      HELP!!!!!
