    Results 1 to 10 of 10
      Feb 2013
      LS cooling fan question
      How is everyone turning there fan off and on are you guys letting the ECU control it or you useing a seprate controller? Iam have a LS3 with dual fans
      Apr 2012
      Woodstock, IL
      We've done a sending unit in the head to turn on the ground for a fan relay or let the computer turn it on. If you have AC then run it thru a trinary switch.
      -Dale
      SchwartzPerformance
      Aug 2008
      Iowa
      Letting the ECU control them both.
      Feb 2013
      Do you run one just to cool engine and bring the other one when the ac is turned on ? Was thinking about useing some type of fan controller
      Dec 2010
      St Louis
      One fan by the ecu, the other with a trinary switch and/or manually adjustable temp sensor.
      Mission Viejo, CA
      I have a Lincoln Mk VIII fan installed for my LS swap, single fan but dual speed. My intention was to allow the ECU (E38) control both low and high speeds of the fan. According to Speartech, the ECU has the ability to do this, and can be reprogrammed to adjust the temperatures that activate each speed if you wire it up properly. Has anyone accomplished this set up?
      1973 Hurst Edition Pontiac Grand Am: 430 CI of ERL built LS7, Tremec Magnum T-56 6-speed, Global West / Speedtech Suspension, Custom rear coil-over suspension, QA1 double adjustable shocks, Wilwood 6/4 piston disc brakes, Modulare C1 19" concave wheels. Shooting for 625 HP and 20 MPG!
      May 2014
      thats an ls2 pcm.. 2005 and above y body
      bowling green,ky
      was using a spal pwm but now using the pcm that came with my terminator efi. works alot better. dang spal piece would default back to factory settings all the dang time.
      Jun 2010
      Stock pcm such as a 0411 has the ability to be programmed to control 2 speeds. You'll need to re-pin one wire on the harness and have the pcm programmed. Check out lt1swap.com for info.
      Oct 2005
      Bay Area CA
      Quote Originally Posted by Later-A-body View Post
      I've been running the Mk VIII fan for years. Since the 1st gen has limited radiator realistate its one of the best fan options IMO. It pulls more air than most duel fan systems. I've allowed my Speartech ecu to control its operation for the past 5 years with zero issues. I spoke with an engineer at Four Seasons (the original fan motor was manufactured by Siemens, Four Seasons now manufactures them in Canada)
      who informed me that in the factory application the fan rarely utilized the low speed option. He said its perfectly fine for it to run on high speed all day long. The only issue I've encountered is with the factory motorcraft connector. It tends to heat up and partially melt over time due to the fans high power draw. I discovered the best fix was to eliminate the connector and hard wire it.
      1968 Restomod FireBird • Twin Borg Warner EFR Turbocharged LS3 • T56 Magnum • Ford 9”• Modern Sub-Frame & Suspension • C7 Seats • 24 Pistons • Forgelines
