      May 2013
      qld Australia
      Country Flag: Australia
      need some advice on P/steer leak.
      got a mustang II rack and pinion connected to a Saginaw Gm pump. port size is 16mm straight cut on return and 14mm on pressure. I am running gottashow custom lines and tried everything to get them to stop leaking. looking for options of what others have done.
      I have tried just using Teflon washers, tried an aluminium washer and thread tape, nex im going to try a thread sealant.
      Mopar or no Car
      Your either with us or Behind us
      Apr 2012
      Woodstock, IL
      Is it leaking between the rack and the straight cut fittings for sure?
      We had an issue before where the fittings weren't threaded deep enough, which didn't touch the Teflon washers inside the rack- they were just seating against the o-rings on the fitting which aren't designed for pressure, just dust sealing. Could be your issue??
      -Dale
      SchwartzPerformance
      May 2013
      qld Australia
      Quote Originally Posted by Schwartz Performance View Post
      -Dale
      the pressure one is leaking between the rack and straight cut and the return is leaking between the nut and swivel head
      would you think if i remove the aluminium washer i have on there now and just use loctite 545 thread sealer and snug it up to try and get it to seat properly?
      Mopar or no Car
      Jan 2010
      Long island NY
      Gm pumps run more pressure than a mustang 2 rack can take stock you might have to reduce the flow
      70 Mustang fastback 428 sb
      May 2013
      qld Australia
      Quote Originally Posted by 1970 TT Rustang View Post
      I do not think this is the issue, but to be honest i am not sure, but i was told with my setup i dont need a flow reducer
      Mopar or no Car
