      Jul 2011
      Hattiesburg, MS
      DIY LS Cam swap Tools
      I was ready to do my cam swap last weekend and forgot to order the valve spring compressor tool so I decided to make one. It worked perfectly so I thought I would share it to help anyone else wanted to make one. Maybe this will help you make yours a little faster. I probably had about 8 hours into making this thing but I didnt have time to wait for it to come in. Attached is a pdf which can be used as a template to make one with notes. This is the spring compressor that I was trying to duplicate.
      Base Plate
      LS3-L92 Valve Spring Compressor.pdf
      1. Cut 1/4 inch steel and drill holes to match the template.
      2. Tap the bottom hole for 1/2" all thread and put about 2" of all thread in the hole.
      3. Weld the bottom of the all thread to the base plate.
      4. Weld 1/4" of washers to the two top holes to make it sit level with the valve cover stud in the middle.
      5. I added 1/8" thick steel plate around the "tongue" to strengthen it but it may have been overkill.
      Spring Plate
      1. Cut 1/4" plate to match the template in the attached pdf or use 1/8" steel with a lip around it for strength. I used 1/8" steel channel that I had available.LS3-L92 Valve Spring Compressor.pdfLS3-L92 Valve Spring Compressor Noted.pdfName:  IMG_2315[1].jpg
Size:  150.6 KBName:  IMG_2314[1].jpg
Size:  160.6 KBName:  IMG_2313[1].jpg
Size:  150.4 KBName:  IMG_2312[1].jpg
Size:  161.8 KBName:  IMG_2310[1].jpg
      Clean it up with a grinder, wipe a little bondo on it to make it pretty and paint it.
      Then I had to install the balancer and couldn't find the all thread anywhere in town. Fastenal usually carries it but they were out of stock. I found a thread over on the Trail Blazer SS forum with a handy tip for building one. TBSS link Buy the $12 coil spring compressing tool in the picture from Harbor Freight. It has the right threads and nuts included. Find some kind of spacer and it works perfect for installing the harmonic balancer.
      Hope this helps someone.
      Jul 2011
      Hattiesburg, MS
      Forgot to mention this was for an L92 so the top left bolt is offset a bit.
      Mar 2014
      Sunny SW Minnesota
      Wow that is one fine tool and I bet you and fun making it! Nice little distraction... I used this tool the last time I did it.
      http://ls1tech.com/forums/tools-fabr...available.html
      It's cheap but would be super simple to make so is way over priced at 35 bucks.
      Jim Stainer
      96 Miata powered by an 02 Camaro SS
      Jul 2011
      Hattiesburg, MS
      I saw that one when I was searching but it was way to easy. What fun would that be right?
      Jul 2011
      Nashville/ Tampa
      I had that Tim's Tool and while it technically works it's slow and I hated it. Plus it's $4 worth of stuff from fastenal. The lingenfelter tool costs more but is worlds better than any of the others I've tried.
      That said, yours looks pretty cool. Looks like you saved yourself a decent amount of $$$.
      https://www.instagram.com/gen_v_lt1_chevelle/
      Do not buy anything from Frankie's Used Auto Parts. Ever.
      Chevelle ̶a̶l̶m̶o̶s̶t̶ ̶f̶i̶n̶i̶s̶h̶e̶d̶ L92/200-4r now Gen V LT1 and T56- https://ls1tech.com/forums/conversio...nvertible.html
