      May 2014
      Los Angeles
      electric fan help
      Looking for some ideas and feed back !!! I have a big block with a be cool aluminum radiator but I have a 16 inch clutch fan with 8 inch electric fan mounted to the front of my condenser , car doesn't over heat stays at 180, In traffic jumps up to 200... But I'm looking to go with a 16 electric fan, what cfm you guys recommend ? Hope to get more power from my motor... Any ideas ?
      Jun 2012
      Cover as much of the radiator as possible with fans. Duals with a shroud might work better for this. Remove the one from in front of the radiator.
      I use only spal fans never had a problem with them.
      Tim
      86 Mustang
      454 LS3 Mast 4500 intake FTI cam Holley EFI Drag radials and pump gas 9.24 143.73
      79 Z28 Bonspeed GT-B DSE front and rear Z51 Brakes 5.3 Holley EFI Vintage Air
      May 2014
      Los Angeles
      electric fan help
      I don't have to much room in 3 to 3 1/2 inch max before I hit the pulley
      May 2014
      Los Angeles
      electric fan help
      What cfm do you recommend ?
      Feb 2009
      muggy midwest
      Are you running a SB or BB radiator? You can get away with using a SB one in aluminum in which you gain an inch of clearance, then trim 3/4 of an inch off the face of a 4400 CFM T-Bird fan shroud and you will be right at the depth limit of 5.75" or a little more. It'll be close but doable. I've done this several times in a variety of 69 Camaros and the fan shroud fits perfect and covers the entire fin opening. Knowing these little subtleties is the difference between a parts seller and a parts seller who is also a builder. (Me)
      "...if at first you don't succeed, try again.
      If you still don't succeed, then quit-no sense being a damn fool about it..."
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
      Southern Indiana
      Heck i cooled my 402 bbc with 3 row copper and brass rad and 91 Cavalier fan assembly in my 70 Monte Carlo. Used a Chrysler temp sender that screwed into head, since had high compression heads used one that turned off at 160 degrees.
      Lee Abel
      AFTERMARKET PERFORMANCE
      Nov 2011
      Virginia
      Quote Originally Posted by Eb67 View Post
      I had the same problem, so I went with a fan from "Cooling Components" out of Memphis, TN since it was only 2-5/8" thick!
      www.coolingcomponentsinc.us.com
      They seem to cater mostly to the street-rod crowd, but their fans are very nice. They come with a molded fan shroud which is a nice piece (pretty thick material) and the fan moves a ton of air. You'll need to figure out how specifically you want to mount it to your radiator, but should be as simple as drilling a few holes for some screws. I've been happy with mine.
