Thread: Welding/ bondo/ moisture
Have seen a lot of photos where the welding seam is built up by lot of small tacks to not warp the sheet metal. I also do the same. I have seen a lot of builds from amatures and pros that dont have the weld fully covered by tacks. Will it be a issue with moisture coming thru the pinholes/ holes from the inside and into the bondo/ filler and create rust? I know some are using epoxy but this is not always. Would it not be better to use lead before bondo/ filler?
Olav
