    Results 1 to 9 of 9
      Aug 2013
      LS6 intake on 383 stroker
      I'm guessing not, but does anyone know if an LS6 intake and injectors will fit onto a chevy 383 stroker motor. Is there modifications to the block to make one fit?
      Pensacola, FL
      Is it an ls1 383 or sbc 383?
      Apr 2012
      Woodstock, IL
      Intake manifolds bolt to the heads, not blocks. There's no possible way of fitting a gen 3/4 intake to a gen 1 or 2 small block.
      LS6 intakes only bolt to ls1/2/6 heads.
      -Dale
      SchwartzPerformance
      Aug 2013
      Yeah I just meant onto a gen 1 or 2 small block engine. So is there any way to put ls1/6 heads onto the sbc? Basically the top end of an ls6 onto the bottom of the small block? I haven't heard anything about it and don't know enough about the ls series engines and their components.
      May 2010
      kitchener,Ontario,Canada
      No...never in a million years would it work.
      My question is why would you want to do that in the first place
      Ryan Austin
      On Instagram ryanaustinss70
      Dec 2010
      St Louis
      Other than the bolt and port pattern differences, you'll have to drill a hole for the distributor......
      Birmingham, AL
      I believe dart makes a block that takes gen 3 and up heads and intakes. I am sure it is pricey though.
      Stephen
      Jan 2011
      Boston, MA
      The intake/exhaust patterns are different too. SBC cam wouldn't work with LS heads/intake. You'd have to do a custom grind. Head bolt pattern is different, intake bolt pattern is different, header pattern is different...
      I think it would be much easier/time efficient to swap an LS in place of your 383.
      Aug 2013
      Yeah I figured it wouldn't work. I am completely happy with my current setup, just was curious.
    Tags for this Thread
