    Results 1 to 11 of 11
      Nov 2013
      SpringHill TN
      Tire width vs. street driving
      Ok I did a bad thing with my sons 67 C-10 over the weekend,We went to Goodguys and run the autocross.!!!!!!!
      The truck is all porterbuilt suspension with ridetech adj. coilovers. I am now hooked and want to do this more but the current 20 inch front and 22 inch rear wheel and tire is not the best setup. It drives great on the road with the 255/40/20 front and 285/40/22 rear nitto 420s tire but not so much for cornering hard or stopping hard.The truck does have a nice set of wilwood brakes on all 4 corners.
      So I am in the market for a new set of wheels and tires. With a new set of lower control arms and a new sway bar the truck would fit a 315/35/20 BFG Rival tire in the front and that tire will fit in the rear easy both on a 11 inch wheel, could even go a 12 in the back if wanted.
      My question is on the street how will that wide of a front tire drive?
      Would I be better off running the 315 out back and the 285 up front?
      Will the 285 bfg be a big improvement over the 255 nitto 420s?
      Sorry for the long post I just do not want to spend a bunch of money and work without getting all the info I can.
      Thanks Joe
      Apr 2012
      Woodstock, IL
      I would probably go the 285 route. The only noticeable issue with wide tires front or rear is the roads travelled. If they are old roads with dips where the cars ride, then the truck may want to weave around the road by itself.
      Is it noticeable between the 285 vs 315? Not sure.
      Your current tire compared to a BFG Rival- you'll be impressed. You may even be ok with the current tire width you have but a set of Rivals! But may as well go bigger..
      If you're looking for Forgeline wheels were a dealer for them FYI.
      -Dale
      SchwartzPerformance
      Lawrenceburg, TN
      the autocross drug has claimed another, did you look at the rim sizes on the other trucks? they were probably all running 18" wheels because on the autocross width is king if you could get a 315 wide tire front and rear you would like the handling of that and you can throw your 20"s back on for daily use....I would look and see what smitty was using along with some of the others truck drivers and that will get you going the right direction
      Hildebran, NC
      .....the autocross drug has claimed another.....
      LOL.
      That was some nice stuff under that truck!!
      Aug 2011
      Livonia, MI USA
      Like Dale posted, the larger front tire will equal more grip for the Autocross, but will cause the truck to "TramLine" easier and make it more difficult to drive on the freeway.
      http://www.tirerack.com/tires/tirete....jsp?techid=47
      Nov 2013
      SpringHill TN
      Thanks for the info guys.
      My next question is when looking at the tire and wheel options is there a preferred wheel width vs tread width. Looking at the 315/35/20 they recommend a 10.5-12 inch wheel and the rim they use to give specs of the tire is a 11 inch wheel. is that what they consider to be the best match?
      Apr 2012
      Woodstock, IL
      Yes the 11" is what is recommended. The 10.5-12 is allowable.
      -Dale
      SchwartzPerformance
      Nov 2013
      SpringHill TN
      Ok guys after a talk with forgeline I am pretty sure thats the wheel I will be running. But I know after buying a 5000.00 dollar lawn more this week and a new to me GMC 3500 truck its going to be a month or 2 before I can place the order.
      I really would like to make the Indy or Ohio Goodguys event to play a little and my nitto 420's on the front really do not do that well. If I bought a new set of front tires to get me by for now my options on the 20x8.5 wheel is limited. I can get the Hankook Ventus R-S3 in the 255/40 which is the same size as I am running now. Would that be a better tire than my current nitto 420? I would like to stick a set of BFG Rivals on the front but the closest offering is a 265/35/20 and I think that would be to wide for the 8.5 wheel.
      Any opinions will be appreciated.
      Apr 2012
      Woodstock, IL
      How old are your nittos? That can have a say into how good they are too. If they're more than a couple years old then those Hankook are probably going to be better no matter what. The 265 Rival would fit on your 8.5" rim, but wouldn't be as ideal as a 245. The Sport comp II isn't that bad of a tire either if it's available in your ideal size.
      -Dale
      SchwartzPerformance
      Oct 2005
      Bay Area CA
      I would recommend a set of Pilot super sports. They'll do well on the course and have a 300 treadwear so they wont get thrashed on the street. Hankooks are made in Korea. They've lightened them up a bit over the years but they're still made in Korea. I'm not a fan of Nittos. Like the Hankooks I think most folks are attracted to their low cost (you get what your pay for). Michelin Pirelli And Continental are the only tire manufactures that should be considered. Again just my opinion.
      1968 Restomod FireBird • Twin Borg Warner EFR Turbocharged LS3 • T56 Magnum • Ford 9”• Modern Sub-Frame & Suspension • C7 Seats • 24 Pistons • Forgelines
      Aug 2011
      Livonia, MI USA
      My recommendation is to match the tread width to the wheel width (bead to bead on the wheel, not overall wheel width) for optimum performance.
      Good Luck!
      Quote Originally Posted by joesbruiser View Post
