      Connecticut
      KATECH LS3 Torquer CAM
      I have a brand new crate LS3 430 hp motor still in the box. I got a great price on it with hopes of adding a cam to it to help boost the numbers a little but still keep it as a nice reliable driver quality motor. Has anyone used the Katech LS3 torquer cam? if i was going to do the cam what else on a brand new motor would you suggest swapping out while upgrading the cam?
      thanks
      Paul Krol
      1968 Camaro
      Feb 2008
      Texas
      That katech cam is a lil expensive for 500 dollars. I got a custom one for $425. Search ls1tech and see what cams they are using over there. They also have a dyno section.
      http://www.youtube.com/user/cutlassrkt?feature=mhee
      69 cutlass - 5.3l L33, Jakes stage 3 4L80e, 275/40/17 proxes tq
      Aug 2001
      Connecticut
      Personally I think it's worth the extra few bucks, yes it probably is a comp cam or similar, my ls7 torquer was made by comp, but given the testing that Katech does, spintron etc if you go with there package it is generally trouble free. Maybe check on corvetteforum for some idle videos, dyno runs, feedback etc in the c6 area. Dan
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Pittsboro, NC
      Always check pushrod length and valve springs with cam change.
