      Apr 2011
      mass
      oil consumption??turbo pcv setup
      I Have a oil consumption issue and I do not run a pcv setup. I am leading to this may be the problem. I have a breather in each valve cover but I have a valley pan under the intake that is tapped and have a barb on it and pushing some oil through that. seems like I am building crankcase pressure. I am thinking about going from the base off the carb to a one way check valve than to the valley pan. I will have a tee screwed into valley pan so I can run another line to the intake tube on the turbo. That should take care off pulling vapor under boost. I have 23inches of vacuum at idle which leads me to believe that I have very good ring sealing. 150psi cranking compression. I know that the oil control rings could be the culprit but this motor has alittle over 200 miles and I am still puffing blue smoke. all cylinders are wet on the top of the pistons also. Any help would be greatly appreciated.
      Thank you
      Paul
      Mar 2004
      Mid-Michigan
      With that few miles I doubt the rings have seated yet. What kind of boost are you running? You are probably getting some blow-by under boost. I would drive it and watch the oil level. Once the rings seat it should get better.
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Apr 2011
      mass
      I am pulling over 20 inches of vacuum at idle so I feel my rings are somewhat seated but feel it is to do with not running a pcv. what type of pcv setups are you guys running with forced induction. I am running a 4150 hp and doesn't have a pcv port on it. Should I run it off off the booster port and run the booster off the full manifold vacuum port on my intake? I do have a open port on the valley cover. Thank you for any help
      Have you looked at the Mann-Hummel ProVent?
      Seems like the perfect solution for your issue: https://www.mann-hummel.com/fileadmi...nt_en_2013.pdf
      ​John Parsons
      Southern Indiana
      I dont understand why a regular PCV valve isnt included while setting cars up, if its inline under boost it slamms closed so as to not pressurize crankcase. Most people I know with custom PCV setups use Grand National valves with great success, also they have told me routing through a remote mounted canister helps IF they get some oil coming through it.
      Another possibility is a vacuum pump setup and I know guy who has both, the PCV valve AND added vacuum pump with remote catch tank attached to one valve cover and a vented cap on remote canister on other side, picked up 5 hp with it!
      Lee Abel
      AFTERMARKET PERFORMANCE
      Dec 2010
      Fredericksburg, VA.
      Oddly enough, a properly designed PCV system is one of the few emmisions systems that is actually beneficial to an engine.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Quote Originally Posted by Steve
      Yep. PCV systems are one reason modern engines last much longer than their 50s and 60s counterparts. No horsepower loss, longer life.
      ​John Parsons
