Results 1 to 11 of 11
Thread: 1969 Camaro project
1969 Camaro project
This is a huge project with a long way to go- but already has a lot done. Willing to sell complete or part out depending on offers and what comes along. Its a 1969 body- New quarter panels on both sides, factory steel doors, New fiberglass hood (bolt on), front fenders, truck lid (with molded rear spoiler), fiberglass header, and fiberglass lower valance. The firewall has been shaved, Drip rails shaved. Rockers are solid. The body has been sitting in primer for 8 plus years. The front clip is stock (never been wrecked or fixed) with urethane control arm bushings and a stock power steering box. It has been welded to sub frame connectors and a 2x3 mandrel bent frame rail that extends all the way to the tail panel. The leaf springs are new with new shackles and moved inward to accommodate a larger tire. It has a stock 10 bolt bolted in to make it roll. The whole floor and trunk sheet metal has been removed and a 10 pt cage has been fitted and tacked in. The original builder was looking to build a street strip pro-touring/ road coarse car. The good news is you have a very blank canvas to build whatever you like. $6500
The motor is a 4 bolt (casting 3970010) with 350hp corvette fuelie heads ( casting 340292). It was also built about 5 years ago and never run. It has new valve springs (larger than factory), new valves, crane rockers with girdles, solid roller crane cam and lifters, forged crank, polished stock rods, bb oil pump, Milidon pan, Hooker super comp headers, chevrolet performance valve covers, victor jr intake, forged srp pistons, MSD billet distributor, msd coil, MSD wires, msd box all new in the boxes, Aluminum flywheel, new clutch, TCI high torque mini starter. $3600
The trans is a Doug Nash 4+1 5 speed thats never been ran. Im currently working on getting the specs from it. Steel scatter shield $2300
I have a whole bunch of other parts that come with the car. Fuel Cell, c4 corvette brakes, 2 brand new Kirkey seats, front and rears sway bars, bolt in style sub frame connectors, stock grille, all the interior and body components minus the glass (window regulators, scissors, ect) ARC wiring harness and switch/ relay box, RCI cam lock seat belts (pair), holley blue fuel pump, Auto meter fuel pressure gauge and adjustable regulator, Full set of auto meter gauges.
Id really like to sell it complete $9500. This would be a perfect low budget build on a stock sub frame/ leaf rear with a mini tub the way it was being built. Or a donor for a full art morrison c6 chassis monster. I have a hot rod shop and could build the car however you like. I of coarse would come down on the price of the car and sell you only the parts you wanted and part out the rest.
925-895-8221 cell 925-978-0089 shop there is a whole album of pictures here http://s36.photobucket.com/user/scot...maro%20oriject
Scotts Speed and Custom
norcal1320.com
