Thread: STARTER problem!!
Ok, I tested the starter and it was fine. I did run a 1/0 ground cable to the starter bolt, but it didn't change anything. I put a load tester on the battery and it said it was a weak battery. When I check it with a volt meter, it has 12.5 or so volts, but drops during cranking. I need to buy a better charger for an AGL battery. I have had the optima bat. on a tender for months so I kinda ruled out a weak bat. Can someone tell me what voltage should the starter see when cranking? I'm assuming 12v.
thanks,
Chris
