    Results 1 to 16 of 16
      Jackson, MI
      Need Ideas - 2010 Console TC Button
      Alright guys, Im in the process of installing a 2010 camaro console in my 67' including the e-brake.
      I'm trying to come up with a cool use for the traction control button.
      The best thing I've been able to come up with so far is to use it as a clutch/neutral safety switch so that it would have to be pressed when the key is turned for the starter to work.
      It would be kind of a security thing but it just might be awkward to use.
      The switch is non-locking so it only works when pressed.
      Any ideas?
      Jason
      67' RS Camaro
      71’ Corvette
      85’ IROC
      Jan 2013
      Las Vegas, NV
      Yeah, that would be awkward, you'd have to reach across with your left hand to push the button while turning the ignition with your right. I'm doing the same install so I'll be watching to see what you come up with. Best of Luck!!
      Scott Atkinson
      68 Camaro SS in progress
      Las Vegas, NV / Redondo Beach, CA
      Hildebran, NC
      Appleton WI
      Line-Lock? :P
      Jim
      1968 Camaro --502HO, ATI 10" TreeMaster, Hughes TH400 with Gear Vendor's OD, Moser 12-bolt, RideTech StrongArms and MuscleBar, Chris Alston G-bar rear suspension, 2 1/8" by 4" Lemon's Headers through 3" Pypes X-pipe and Hooker AeroChambers.
      Sep 2008
      Jacksonville, Florida
      I'm pretty sure that is a MUX or BUS switch. It's not designed to handle amperage.
      Craig Scholl
      CJD Automotive, LLC
      904-400-1802
      www.cjdautomotive.com
      "I own a Mopar, I already know it won't be in stock, won't ship tomorrow, and won't fit without modification."
      Jackson, MI
      I like the ejector seat idea but knowing my kids they would be using it to shoot eachother over the house.
      Jason
      67' RS Camaro
      71’ Corvette
      85’ IROC
      Jackson, MI
      I figured I would probably have to have a relay in there somewhere.
      Jason
      67' RS Camaro
      71’ Corvette
      85’ IROC
      Dec 2009
      Put a traction control unit on the car and make it functional?
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      San Antonio, TX
      You could use several relays and make it a momentary switch to get the fuel pump going, and continue self stimulating the circuit until you turn the car off.
      i would rather use it as a starter kill though.
      Not all the answers here, but plenty of ideas:
      http://www.diyaudio.com/forums/parts...ne-switch.html
      Dave
      Dec 2013
      Quote Originally Posted by Ron.in.SoCal View Post
      this guy and his logical suggestions... you know we dont do that around here =p
      Jackson, MI
      Traction controll would be too easy and way too obvious.
      Jason
      67' RS Camaro
      71’ Corvette
      85’ IROC
      May 2010
      kitchener,Ontario,Canada
      Nitrous?...fuel pump switch ..electric fan....amplifier...gps...radar...Cmon. Here lots of uses
      Ryan Austin
      On Instagram ryanaustinss70
      Dec 2013
      missiles? lasers? miniguns? mk19's?
      Sep 2008
      How about an ignition kill so you can spin the motor and not fire until oil pressure is present.
      Craig Scholl
      CJD Automotive, LLC
      904-400-1802
      May 2010
      Power trunk release or even auxiliary lighting switch
      Ryan Austin
      Sep 2013
      not exactly answering your question here, but if you can match the paint on the button, you could paint over it then go to a place that does laser engraving and have them etch another icon there.
      another option, since it's abs is to just graft in a filler piece and delete the button all together.
      i did something similar for my corvette a while back in order to get a smooth surface to graft a tapered pipe reducer smoothly:
      cup holder delete:
      http://i.onfinite.com/mtZMB5zqd.jpg
      final result after grafting in an abs pipe reduction fitting:
      http://i.onfinite.com/mfC3hZNqd.jpg
      if you want to go that route, let me know and i can walk you through the process
      Scott
      '66 Chevelle
