Results 1 to 10 of 10
Thread: Carb tuning help
09-19-2005 #1
- Dec 2004
- Caledonia Ontario Canada
- 50
Carb tuning help
I just broke in my new engine. Its s 383 small block chev with 9.7-1 comp ratio, XE274 comp cam flat tappet, 200cc procomp aluminum heads and a vic jr intake. Carb is a Holley 750 vac secondary 3310 model. The fuel pressure is set at 6 psi. After driving for a bit the secondaries will start to drip fuel into the carb at idle. I imagine it is doing this while driving also as the car seemed to load up when I slowed down for my first stop. Float level seems good. Primary jets are 72 right now. Engine idles at about 750-800 RPM with about 9 inches of vacuum. Plugs are super black. What power valve would you guys recommend and what do you think could be done about the fuel dripping into the secondaries? Are the jets a good size or should I go bigger/smaller? Thanks
